Webcast-Catalyst9k
Full BGP on 4500
Can the Cat 4500 support multiple BGP peers that are sending full tables? How much RAM is needed? Has anyone seen this in production?
Lee
1 ACCEPTED SOLUTION
Re: Full BGP on 4500
The Cat4500 can't take a full table regardless of RAM. They have a max of 131,072 entries in the routing table, unicast and multicast combined. See the "Predictable Performance" section of the data sheet:
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheet0900aecd801c5c66.html
look at this link:http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheet0900aecd803fae7d.html#table1
and i think amount of RAM is depends on your network design and configuration of aggregation as well as summerisation...
regards
Devang
Hi Lee,
Which sup engine you are running. It has to be Sup4/5/5-10GE. These are the only sup engines which support full layer 3 routing protocol funcationality. These all comes with default 512MB and it should be suffiient to get the full routing table on them. Depends on how many BGP sessions you have that are feeding the router a full table but 128MB is the effective minimum.
HTH,Please rate if it does.
-amit singh
Thanks Amit!
Is the Sup4/5/5-10GE blade upgradeable to 1gb ram? Are the other sup blades for the 4500 upgradeable also?
thanks,
Lee
Hi Lee,
No, Supervisor engine on Cat4500 are not upgradable to 1GB.They defualt on 512MB.
HTH,
-amit singh
595
