Community Member
Funny Characters while configuring 1841 Router
While changing the ISO of a 1841 router, same funny character appeared while on Rommon> command. How do I get rid of these funny characters ?
Community Member
Re: Funny Characters while configuring 1841 Router
Check you console baud rate set correctly and config register value is set to 0x2102
Good luck
Community Member
Still doesnt work. Every time it boot still funny characters appear and if i press any button on the keyboard it in replaced with symbols. What do i have to do next??
Community Member
Check wether your flash card insert properly. Change the baud rate to 115200 and try.
Community Member
I off the switch on the Router inserted the flash card but it is still the same, everytime it boots funny character appear on the Hyper Terminal, even when i press a letter on the keyboard, it appears with some funny characters. Is there any possible solution for these problem ??
Community Member
this is a classic case of mis-matched baud rates on the router and the PC.
You need to do a trail and error method and use the available baud rates from 110 to 921600.
I am sure this will solve the problem.
-Sai.
660
