10-07-2013 05:20 AM - edited 03-04-2019 09:14 PM
We are experiencing some high cpu utlilization in our FWSM blade and i would like your opinion if this is normal. Sometimes the CPU touches 90% utilization.
FWSM/act# sh ver
FWSM Firewall Version 4.0(7)
Device Manager Version 6.2(3)F
Compiled on Tue 08-Sep-09 20:48 by fwsmbld
FWSM up 59 days 17 hours
failover cluster up 59 days 17 hours
Hardware: WS-SVC-FWM-1, 1024 MB RAM, CPU Pentium III 1000 MHz
Flash STI Flash 8.0.0 @ 0xc321, 20MB
0: Int: GigabitEthernet0 : address is 0021.d80c.e300, irq 5
1: Int: GigabitEthernet1 : address is 0021.d80c.e300, irq 7
2: Int: EOBC0 : address is 0000.1100.0000, irq 11
Licensed features for this platform:
Maximum Interfaces : 256
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
BGP Stub : Disabled
Service Acceleration : Disabled
VPN Peers : Unlimited
Serial Number:
FWSM/act#
FWSM/act# sh cpu usage
CPU utilization for 5 seconds = 34%; 1 minute: 39%; 5 minutes: 40%
HC-6500-FWSM/act# show processes cpu-hog
MAXHOG NUMHOG LASTHOG Process
120 7 110 fast_fixup
200 1 200 fover_rep
200 6 190 ssh
160 7 150 ssh
160 2 160 accept/http
200 1 200 qos_metric_daemon
FWSM/act# sh conn count
9137 in use, 41843 most used
FWSM/act# sh processes memory | e 0
Allocs Allocated Frees Freed Process
(bytes) (bytes)
59715 5185868 83348 6187656 accept/http
29 174224 6 264 fover_thread
2 14 1 2 sqlnet
967 192942 967 192942 aaa
4 4297 1 13 ScpIncomingThread
6 5372 6 24972 Session Manager
6 44162 4 16648 route_process
9 396 9 396 fover_FSM_thread
26 17725 1 1281 ci/console
1336 88358 32 133184 websns_keepalive
4 8412 2 88 fover_ip
3252 26528 971 258742 tacplus_snd
8 352 8 352 fover_rx
8 352 8 352 lu_rx
On the MSFC:
WAN#sh module
Mod Ports Card Type Model
1 6 Firewall Module WS-SVC-FWM-1
2 6 Firewall Module WS-SVC-FWM-1
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B
Mod MAC addresses Hw Fw Sw Status
1 001f.ca08.74c2 to 001f.ca08.74c9 4.3 7.2(1) 4.0(7) Ok
2 001f.6c88.6232 to 001f.6c88.6239 4.2 7.2(1) 4.0(7) Ok
5 0017.9444.d3bc to 0017.9444.d3bf 5.4 8.4(2) 12.2(33)SXI9 Ok
Mod Sub-Module Model Hw Status
3 Centralized Forwarding Card WS-F6700-CFC 4.1 Ok
5 Policy Feature Card 3 WS-F6K-PFC3B 2.3 Ok
5 MSFC3 Daughterboard WS-SUP720 3.0 Ok
WAN#sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXI9, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Fri 24-Feb-12 21:38 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
WAN uptime is 8 weeks, 3 days, 17 hours, 32 minutes
Uptime for this control processor is 8 weeks, 3 days, 17 hours, 27 minutes
Time since GB-LON-HC-01-WAN switched to active is 8 weeks, 3 days, 17 hours, 26 minutes
System returned to ROM by reload (SP by reload)
System restarted at 19:40:39 BST Thu Aug 8 2013
System image file is "sup-bootdisk:s72033-advipservicesk9_wan-mz.122-33.SXI9.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco WS-C6509-E (R7000) processor (revision 1.3) with 458720K/65536K bytes of memory.
Processor board ID
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
6 Virtual Ethernet interfaces
120 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Any ideas?
TIA,
Nicos Nicolaides
