does anybody know the recommended parameters for G.SHDSL link? I have two routers 878 connected back-to-back using G.SHDSL, but the connection is failed. The parameters of this link are following:
Resist. - 61,5 OHM
Length - 282,4 m
Delay - 1233 ns
Imped. - 131
Attenuation - -44,8
The configuration is good, because the connection is up on the shorter distance. I'm using two-wire cable with pins 4-4, 5-5. I tried to find this recommended parametrs on CCO, but without success. Thank you.
