G703/G704
controller E1 x/y/z
channel-group 0 timeslots 1
channel-group 1 timeslots 2
<repeat for all needed channels>
interface serial x/y/z:0
ip address ...
Kindly give me the complete sample configuration of about mention configuration commands.(G703/G704)
Re: G703/G704
Your question doesn't really make any sense. The config listed above is for framed operation, which is different to G703.
For unframed G703, you use this CLI snytax -
controller e1 0/0/0
channel-group 0 unframed
interface serial 0/0/0:0
ip address ...
This then makes the entire E1 a single channel group.
http://www.cisco.com/en/US/docs/ios/12_1t/12_1t1/feature/guide/dtg703.html
Hall of Fame Super Gold
Re: G703/G704
Paul, Adnan is following up to an answer of mine. He needs info about channelized information.
Adnan, these are all the commands required. If the hardware is a vwic2, you also need "card type E1 ".
Re: G703/G704
a g703 e1 card vwic2 doesnt need the card type command as it is only an e1 card it is not an e1/t1,hth
Re: G703/G704
On the other hand, the expensive vwic2 G.703 version is wasted for a channelized application, because it is really made for the unframed application that Paul mentioned before.
202
