Webcast-Catalyst9k
GBIC and Mini-GBIC
Are these two comparable?
If one switch uses GBIC and the new switch uses mini-GBIC, then can they communicate with no problem?
Re: GBIC and Mini-GBIC
Yes, they can, as long as they use the same standards. Both ends should be either Single mode or Multi mode. Also if one end is a Shorthaul gbic, the other has to be a shorthaul too.
All you need to interconnect the two gbics is a fiber cable (cross over Rx->Tx, and Tx - Rx), with one end SC (WS-5484 gbic) and the other end with LC (For SFP Gbic)
Is there any documentation on this? I need to show prove of this otherwise I will not be approve to buy the new switches.
265
