06-13-2006 03:51 AM - edited 03-03-2019 12:59 PM
Hi all,
I have the following router 7609.
------------------ show version ------------------
IOS (tm) s72033_rp Software (s72033_rp-PK9SV-M), Version 12.2(18)SXD3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Thu 09-Dec-04 22:59 by pwade
Image text-base: 0x4002100C, data-base: 0x42318000
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-PK9SV-M), Version 12.2(18)SXD3, RELEASE SOFTWARE (fc1)
Router uptime is 35 weeks, 4 days, 21 hours, 9 minutes
Time since router switched to active is 35 weeks, 4 days, 21 hours, 10 minutes
System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19 (SP by power-on)
System restarted at 15:05:20 DST Thu Oct 6 2005
System image file is "sup-bootflash:s72033-pk9sv-mz.122-18.SXD3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco CISCO7609 (R7000) processor (revision 1.1) with 983008K/65536K bytes of memory.
Processor board ID FOX090900TQ
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
8 Ethernet/IEEE 802.3 interface(s)
9 Virtual Ethernet/IEEE 802.3 interface(s)
74 Gigabit Ethernet/IEEE 802.3 interface(s)
8 Gigabit Ethernet/IEEE 802.3 interface(s)
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
and I issued
interface GigabitEthernet1/7
mtu 9216
no ip address
speed nonegotiate
interface GigabitEthernet1/8
dampening
mtu 9216
ip address X
no ip redirects
no ip unreachables
ip rip advertise 15
These interfaces don't get up
I have checked the fiber and it's good.
I have attached the "show interface" command
What could be the solution?
Thanks a lot in advance,
Beatriz
06-13-2006 03:58 AM
HI
Have u connected something to it i mean any device or its a trunk port.Perfrom a no shut under u r interface.
Mahmood
06-13-2006 04:33 AM
Yes, I had performed a no shut under, but interfaces don't get up. Also, I have made loops but I doesn't work either..
Thanks a lot!
Beatriz
06-21-2006 12:25 AM
Are you sure that you use the correct optical cable - I mean single mode or multi mode. And double check the polarity (Rx, Tx).
Bye,
FCS
06-21-2006 02:40 AM
how come ur both the gigabit interface are having same MAC address. just check ur show int output and if possible it could be hardware address. log a call to cisco-tac get it replaced.
06-21-2006 03:26 AM
Hi all,
I want to thank you, your useful responses. The problem is solved. We have taken out module and inserted again and all ports are working properly.
Thanks a lot!!
Have a nice day :)
