GLBP configuration
Just wondering if someone had a sample config of GLBP on VLAN's (a complete config not just snippets here and there) or if there was a link to such a config.
Blue
Re: GLBP configuration
This document has a step by step config guide with some examples.
http://www.cisco.com/en/US/products/ps6550/products_white_paper09186a00801541c8.shtml#wp1027258
Please rate helpful posts.
I've already seen this document. It applies GLBP on an physical interface and not a VLAN. I'm looking for an example of GLBP on a VLAN.
Blue
The commands will be the same, just interface vlan XXX.
hi download the pdf ... its good document for the GLBP...
rate this post if it helps
regards
Devang
thanks. I kind of figured about putting the glbp portion in my "int vlan 999" but is there something else that I need under the sub-interface to make it work (int gig 3/24.999)? My 'show standy brief' doesn't show anything (just a blank line)
876
