Webcast-Catalyst9k
GLBP weighted load balancing
I have 2 routers that connect via P2P to other 2 routers one is using 512kps and the other a full T1. I want to be able to use both interfaces via GLBP sending 3 packets to the router that has T1 and 1 to 512kps link. How do i configure this?
routerA ----- T1 ---- routerB (GLBP)
routerA-1 ---- 512kps ---- RouterB-1 (GLBP)
Thanks in advance
Re: GLBP weighted load balancing
you'll need the command
glbp group load-balancing weighted
then use:
glbp group weighting maximum
to specify each router a specific weight
hope this help a bit
Vlad
I want to use the total bandwitdh available on both routers (T1+512kps) in a GLBP fashion. Im using the bandwidth 1544 on both BLGP routers to allow the EIGRP routing use both, otherwise
it will prefer the T1 only.
Let me know if the weighted is correctly.
Any suggestings are appreciated.
Mario
routerA ----- T1 ---- routerB (GLBP)----using EIGRP
routerA-1 ---- 512kps ---- RouterB-1(GLBP)--using EIGRP
routerB# (T1)
interface fastethernet 0/0
ip address 192.168.1.2 255.255.255.0
bandwidth 1544
glbp 10 192.168.1.1
glbp 10 authentication text XXXX
glbp 10 load-balancing weighted
glbp 10 weighting 150 lower 150 upper 150 ********????
glbp 10 priority 254
glbp 10 timers 5 18
RouterB-1# (512kps)
ip address 192.168.1.3 255.255.255.0
bandwidth 1544 ------------------------needed to allow EIGRP use both interfaces
glbp 10 192.168.1.1
glbp 10 weighting 50 lower 50 upper 50 ********?????
glbp 10 timers 5 18
194
