going from 12.3 to 12.4 on 1721 with Frame Relay
I am going to update a 1721 router from 12.3 12.4(16b) and their is a command in the frame realy Virtual-Template that gets dropped I think it doesn't matter but want to make sure. the command is the "ppp ipcp route default" below is the Virtual Template configuration. Any Thoughts...
interface Virtual-Template1
ip address negotiated
ip nat outside
ip virtual-reassembly
ppp chap hostname xxxxxxxxx
ppp chap password xxx
ppp ipcp dns request
ppp ipcp address accept
1 REPLY
Hall of Fame Super Silver
Re: going from 12.3 to 12.4 on 1721 with Frame Relay
Hello Bob,
you are doing PPP over Frame-Relay.
first idea:
the command could be hidden by a change in defaults with the new release so you don't see it but it is still effective
second thought:
you can configure a default static route in global config using the virtual-template as outgoing interface to get a similar result
see
http://www.cisco.com/en/US/docs/ios/dial/command/reference/dia_p1.html#wp1014725
This command allows a PPP virtual template to dynamically add a default route pointing to the virtual access interface created by the virtual template.
A customer premises equipment (CPE) router with PPP over an ATM or Frame Relay connection can access the Internet without turning on any other routing.
So if you are providing a default route in another way or using any form of dynamic routing over the PPP link I agree it will not be a problem.
Hope to help
Giuseppe
162
