04-21-2010 02:26 PM - edited 03-04-2019 08:14 AM
Within a router, Is PAK_Priority preserved once a packet is encapsulated in GRE? In other words, if a EIGRP packet had PAK_priority set and was then encapsulated in GRE, does the GRE packet now have PAK_priority set?
04-21-2010 02:38 PM
Daniel
PAK_priority marks routing protocols to DSCP CS6 so once the packet has been encapsulated in a GRE header then the header will have the DSCP value but obviously it is then up to the intermediate routers to honour that value.
Jon
04-21-2010 02:46 PM
Jon,
Thanks for the quick response. I knew that all routing protocols get marked to CS6, but I thought that PAK_Priority was an additional internal flag that was used within a router to ensure those packets were forwarded on a congested interface. The question I have is, if the original EIGRP packet had the PAK_priority flag, does that carry to the GRE packet that ultimately gets forwarded out the interface?
04-21-2010 02:50 PM
danieweber wrote:
Jon,
Sorry, i didn't explain it very well.
PAK_Priority is indeed an internal flag that tells the local router what to do with this packet if the interface is congested. This is not copied to the GRE header. What is copied is the CS6 value but only the router at the other end of the GRE tunnel will actually see the PAK_Priority in the initial packet once the GRE header has been removed.
Jon
04-23-2010 08:05 AM
Jon, I thought that PAK_priority was an internal flag used by the router and not used externally. Can you confirm that the other GRE endpoint would see the PAK_priority flag after the GRE header is removed?
