11-16-2011 04:51 AM - edited 03-04-2019 02:17 PM
I have a Cisco 4900m switch, which has a GRE tunnel interface configured on it.
We have two networks 172.16.0.0/21 and 172.16.8.0/16. Both these networks use the same Internet pipe.
The internet pipe includes to network ranged 71.20.111.0/26 and 71.20.111.64/26. The DG for those two
networks are 71.20.111.1 and 71.20.111.65. The default route on the Cisco 4900m switch is
the 71.20.111.65 address.
VLAN768 = 172.16.8.0/21 VLAN199 = 172.16.0.0/21
interface Vlan768
ip address 172.16.8.9 255.255.248.0
ip policy route-map ZSCALER_WEB
Anything in the 172.16.8.0/21 network uses this interface as it's default gateway.
The route-map is configured as follows
route-map ZSCALER_WEB permit 10
match ip address ZSCALER_WEB
set ip next-hop 172.17.160.146
The ZSCALER_WEB ACL is as follows
ip access-list extended ZSCALER_WEB
permit tcp any any eq www
permit tcp any any eq 443
So, anything matching the ZSCALER_WEB ACL is PBRd to a next hop of 172.17.160.146.
Tunnel0 Configuration
There is a directly connected interface, which is Tunnel0 to the 172.17.0.0/30 network.
So I would assume, once it PBRs the specified traffic it arps it out to 172.17.160.146, since it
is the next hop.
interface Tunnel0
description Zscaler GRE tunnel--primary
ip address 172.17.160.145 255.255.255.252
ip mtu 1476
ip tcp adjust-mss 1436
keepalive 10 3
tunnel source Loopback0
tunnel destination 216.52.207.65
interface Loopback0
ip address 71.20.111.117 255.255.255.192
On a user on VLAN199 (172.16.0.0/21) the next hop is as follows
1. 71.20.111.65 (This is the correct hop according to our routing)
2. 10.66.18.161 (This addres is inside the SP's network)
On a user on VLAN768 (172.16.8.0/21) the next hop is as follows
1. 172.16.8.9 (This is the correct hip according to our routing)
2. 10.66.18.161 (confusing because the only way to get to this network is through 71.20.111.65)
What I dont understand is, why VLAN768 doesn't have 71.20.111.65 as it's next hop after 172.16.8.9.
The only way to get to 10.66.18.161 is through 71.20.111.65?
Sorry for the long post guys.....
11-16-2011 09:13 AM
I don't think it's tunnel, because the routing has changed on the hop after the 4900 switch.
11-16-2011 09:26 AM
Well, I can't locate where the next hop is to be perfectly honest with you.
I know the next hop, for things that have been PBRd(vlan768) go to 172.17.160.146, which is
a directly connected interface according to the 4900. Also, if it's not HTTP/HTTPS according
to the route-map it follows your normal routing rules, which will match the default route
that goes to 172.16.8.1, which is on the wireless ASA, which has a default route to
71.20.111.65. It's very confusing to say the least.
11-16-2011 09:32 AM
Color me stupid... The next hop for HTTP/HTTPS traffic is the other isde of the
GRE tunnel0. But, that still doesn't make since why non HTTP/HTTPS traffic would not hit 71.20.111.65 since it follows
the same rules as the other network outside of HTTP/HTTPS.
11-16-2011 01:38 PM
just to be sure that we don'T really have a problem with PBR and a Tunnel - just remove the PBR configuration and test the trace without it.
11-17-2011 05:17 AM
Well, once I removed the PBR configuration, and when I did a traceroute to 8.8.8.8 from a 172.16.8.0/21 network, it's first hop turned out to bbe 71.20.111.65. So, I decided to put i back, and it almost looks like it's load balancing.
If I do a traceroute to any new flow it goes to 172.16.8.9 and then the follow traceroutes to the same IP gets 71.20.111.65.
11-17-2011 06:10 AM
it's really strange.
Try to find out how the normal routing looks like on all transit devices, just do "sh ip route 8.8.8.8" find the next-hop IP and then "sh ip route
11-21-2011 11:24 AM
I decided to give up on it for right now. This wireless network will be going away anyway....
Thanks for all the help Konstantin, I learned a lot via your posts.
