GRE aware VRF
nivic
Hello, team!
I have cat6500 (sup-720) and I want configure gre tunnel within VRF. I used next configuration:
ip vrf test
rd 100:100
interface Tunnel0
ip vrf forwarding test
ip address 172.31.254.253255.255.255.252
keepalive 5 3
tunnel source 10.112.86.6
tunnel destination 10.112.86.20
tunnel vrf test
interface Vlan10
ip address 10.112.86.6 255.255.255.192
interface GigabitEthernet4/28
no ip address
switchport
switchport access vlan 10
switchport mode access
spanning-tree portfast
I can ping tunnel destination from cat 6500 but tunnel didn't work.
sw-core#sh int tunnel 0
Tunnel0 is up, line protocol is down
Hardware is Tunnel
Internet address is 172.31.255.253/30
MTU 1514 bytes, BW 9 Kbit, DLY 500000 usec,
Encapsulation TUNNEL, loopback not set
Keepalive set (10 sec), retries 3
Tunnel source 10.112.86.6 (Vlan10), destination 10.112.86.20, fastswitch
TTL 113
Tunnel protocol/transport GRE/IP, key disabled, sequencing disabled
Tunnel TTL 255
Checksumming of packets disabled, fast tunneling enabled
Last input 01:27:32, output never, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 8053
Queueing strategy: fifo
Output queue: 0/0 (size/max)
7847 packets input, 419400 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicast)
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
Where am I mistake in the configuration file?
10 Replies 10
spremkumar
Level 9
Level 9
hi
Can you revert about the remote end where this GRE is getting terminated ??
Also the configs from the remote device related to GRE and also the show interface GRE..
regds
I am sorry! I forgot config for another end.
cat 3750
interface Tunnel10
ip address 172.31.255.253 255.255.255.252
keepalive 10 3
tunnel source Vlan10
tunnel destination 10.112.86.6
interface GigabitEthernet1/0/1
interface Vlan10
ip address 10.112.86.20 255.255.255.192
3750#sh int tunnel 10
Tunnel10 is up, line protocol is up
Hardware is Tunnel
Tunnel source 10.112.86.20 (Vlan10), destination 10.112.86.6, fastswitch TTL 255
Tunnel TTL 255
Last input 01:40:56, output 00:00:02, output hang never
Last clearing of "show interface" counters 01:17:49
0 packets input, 0 bytes, 0 no buffer
467 packets output, 22416 bytes, 0 underruns
38 packets input, 2964 bytes, 0 no buffer
508 packets output, 27780 bytes, 0 underruns
hi
I dont think the tunnel will come up coz @ one side you have applied VRF under that and on the other side u dont tht.
By applying VRF under that ur bringing that interface as a member of a particular MPLS VPN.
Since you have keepalives in place it will try to check the connectivity and it wont be able to get that established coz of the other side which is not the participating in the same vpn.
AFAIK If u want to bring the tunnel up then u shuld have the vrf forwarding configured on the other side too as well the necessary RT,RD values to enable the communication between them.
once ur thru with that u need to have normal (VPNV4)MP-BGP sessions to be configured between these devices to exchange the routing info.
Also clarify the purpose and the requirment to have this kinda topo over there..
you will be able to ping the ip address of the destination coz the ip will be reachable to u.
using an extended ping u cant ping the remote tunnel interface ip address with souce as ur local tunnel interface ip address from both the sides.
regds
hi
I dont think the tunnel will come up coz @ one side you have applied VRF under that and on the other side u dont have tht.
By applying VRF under the tunnel interface ur bringing that interface as a member of particular MPLS VPN.
Since you have keepalives in place under the tunnels it will try to check the connectivity and it wont be able to get that established coz of the other side which is not the participating in the same vpn.
AFAIK If u want to bring the tunnel up then u shuld have the vrf forwarding configured on the other side too as well with the necessary RT,RD values to enable the communication between them.
regds
Harold Ritter
Is the tunnel destination resolvable via the VRF or the global RIB? The command "tunnel vrf test" instruct the tunnel to resolv the tunnel destination via the VRF. So unless you can resolv the tunnel destination via the VRF the tunnel won't come up.
If your goal is to establish the tunnel via the global RIB then just remove "tunnel vrf test".
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Tunnel destination resolve via VRF. I can ping tunel destination from vrf (ping vrf test 10.112.86.20).
sh ip ro vrf test
Routing Table: test
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static
route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
10.0.0.0/26 is subnetted, 1 subnets
C 10.112.86.0 is directly connected, Vlan10
30.0.0.0/24 is subnetted, 1 subnets
C 30.30.30.0 is directly connected, Loopback
#ping vrf test 10.112.86.20
Sending 5, 100-byte ICMP Echos to 10.112.86.20, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
but tunnel is down.
What level of code are you running on the Sup720. It should definitely work. Can you just remove the keepalive on the Sup720 side to see if the tunnel comes up?
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
I use IOS 12.2(18)SXD6
IOS (tm) s72033_rp Software (s72033_rp-PK9SV-M), Version 12.2(18)SXD6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 17-Aug-05 18:13 by evmiller
Image text-base: 0x4002100C, data-base: 0x42320000
I did a bit more research and it looks like creating a tunnel through a VRF is not yet supported in the 12.2SX code train.
BTW: the fact that the "tunnel vrf" command was available in 12.2(18)SXD was probably an oversight. This command has been removed in 12.2SXE and SXF.
I tried and it works in 12.0S and 12.4, which doesn't help in your case.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
I opened case to cisco TAC and I received similar answer.
it's a feature which at this point has not yet been added to the cat6k list of features.
I cry :-(
Thanks hritter and all
