04-27-2006 02:54 AM - edited 03-03-2019 12:32 PM
does anyone know the place to start with the configurations on GRE/IPSEC using EIGRP on 3360 as Main and 1821 as Remote Routers. samples or configuration setups links would be helpful
04-27-2006 05:18 AM
Once you can ping site to site, start configuring GRE tunnel. Then use GRE interface IPs to create IPSec crypto maps.
Hope this helps.
04-29-2006 08:40 AM
thanks, but that was the point as if anyone can point some good links to read out and start the configuration or sample configurations.
04-29-2006 08:46 AM
you need something like this?
Configuring a GRE Tunnel over IPSec with OSPF
http://www.cisco.com/warp/public/707/gre_ipsec_ospf.html
Configuring IPSec/GRE with NAT
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080094bff.shtml
Vlad
