GRE over IPSec ( in a redundant WAN)
netcentre
All,
     I am attempting to encrypt the traffic on this WAN ( Please attached diagram). The creation of the GRE tunnel was successful, the pronlem occurs when i apply the encryption to the remote router (LBI) and the host router (LBI) i am unable to see anything after the tunnel.
Please see attached files with configuration for two routers. ISD=Host, LBI=Remote. Can someone tell where i am going wrong.
Quincy
2 Accepted Solutions
Orson
The config for the ISD router still shows the crypto map applied to the tunnel interface. Unless you are running quite old code on these routers the crypto map should be only on the physical interface.
Also the access list has two lines. You only need the first line which permits the GRE traffic. I suggest that you remove the line
Access-list 110 permit ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
Rick
Rick
All other traffic is encapsulated in GRE, so, in essence, it will be encrypted as well.  I employ Richard's suggestion frequently, and it works well.
-Chris
8 Replies 8
cflory
Orson,
Firstly, you won't have to specify the 'crypto map' statement on the tunnel interface, the physical should suffice.  Also, you need to set your tunnel sources correctly:
ISD Router:
Tunnel source should be FastE0/1.1
LBI Router:
I am not sure how you got the GRE tunnel working with this configuration, as you mentioned in your second sentence.  Unless there is some other configuration I'm not seeing.
Also, apply the crypto map to the FastE0/1.1 interface instead of FastE0/1.2.
HTH!
-Chris
Chris,
     There was a mistake in the configuration, its now corrected in the document.
Orson
Orson
Rick
Rick
It is working without the access-list mentioned above, however all the documentation I read suggests to "create access lists to define the traffic for encryption". I interpret that to mean all traffic that is passing between the sites.
"The crypto access list will specify which data traffic will pass through the IPSec
tunnel. Crypto access lists are more like security associations than traditional ip
access lists. “…the access lists used for IPSec are used only to determine which
traffic should be protected by IPSec, not which traffic should be blocked or
permitted…”. "IPSec Network Security" cisco systems inc
If we remove that access-list line, then only the GRE traffic will be encrypted... what happens to the other traffic?
-Chris
Chris
Thanks for the good explanation and for the endorsement of my approach.
The paragraph that Orson quotes does apply to a standard IPSec tunnel (without GRE) and I suspect that if he completely identified the source we would find that it was in fact discussing an IPSec tunnel that does not use GRE.
The basic point is still true - that the access list identifies the traffic to be encrypted. But when the data traffic is forwarded through a GRE tunnel then the traffic to be encrypted is nothing but GRE.
Rick
Rick
netcentre
Thanks for the clarifications
Orson
I am glad that we were able to supply answers that helped to solve your question. Thank you for using the rating system to mark the question as resolved. It makes the forum more useful when people can read a question and can know that an answer was found. Your marking has contributed to this process.
Rick
Rick
