GRE over IPSec Tunnel bouncing for few seconds every 90 seconds.
Hi Cisco experts,
I have a situation where one of the GRE Tunnel keep on bouncing for only 1 or 2 seconds in every 90 seconds period.We have troubleshoot and check the physical cabling and find out that there is no issue. Event the internet conenction is clean. We can ping both destination from each routers without any abvious time out.
I have attached the configuration sample and also the debug EIGRP logg that I get from the router.
Appreciate your help on this.
Thanks!
Re: GRE over IPSec Tunnel bouncing for few seconds every 90 seco
hello ,
dynamic routing over gre , you can try to modify config red line below.
interface Tunnel16
description Router-TU16-NKEHKGR01-TU16-GRE Over VPN
bandwidth 5000
ip address x.x.x.x 255.255.255.252
ip route-cache flow
tunnel source FastEthernet0/0.2
tunnel destination 10.248.6.189
no  keepalive 10 3
Hi Wang,
Thanks for the reply. Should I replace the keepalive configuration at both end?
hello ,
yes  , both end . hope to help.
I had similar issue and found IOS as the issue. I recollect the router was 1841
Is GRE Tunnel and IPSEC config on the same router. Can you post the full configuration including show version.
Thanks ST
ST,
Below are the sh ver output :-
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(16), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 20-Jun-07 07:19 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Router uptime is 5 days, 10 hours, 0 minutes
System restarted at 07:36:52 AET Thu Jul 8 2010
System image file is "flash:c2800nm-advipservicesk9-mz.124-16.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FHK1221F44C
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Guys,
FYI this issue was cause by the EIGRP’s Retry Limit Exceed. It has been solved by adjusting the mtu size of the tunnel. We found out that there is a mtu size limitation on the provider end.
Thanks all on the input given on troubleshooting this issue.
Azmir.
1902
