GRE over MPLS txload 255/255 rxload 255/255
vishalsinha
Hi friends,
I have a MPLS cloud between sites and i usually send all my internet traffic to data centre as i have a MIS circuit there. recently we took a MIS circuit in AP region on one of our site. we created GRE tunnels to send the internet traffic of other AP locations to this site and if that circuit goes down then your the Data Centre internet circuit.
The tunnel i have created shows me
Tunnel1 is up, line protocol is up
  Hardware is Tunnel
  Description: << GRE tunnel for Internet traffic >>
  Internet address is 1.1.1.1/30
  MTU 17916 bytes, BW 100 Kbit/sec, DLY 50000 usec,
     reliability 255/255, txload 255/255, rxload 255/255
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 164
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  5 minute input rate 937000 bits/sec, 185 packets/sec
  5 minute output rate 124000 bits/sec, 153 packets/sec Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 164
I was getting error IP_VFR-4-FRAG_TABLE_OVERFLOW: Tunnel1: the fragment table has reached its maximum threshold 16 alos. that i corrected by adding "ip virtual-reassembly in max-reassemblies 512" command to tunnel interface.
Need your help.
There is a quite simple explanation about 255/255. Look at the actual input and output rates
and compare them to the bandwidth assigned for the tunnel interface
BW 100 Kbit/sec
It is pretty obvious that both transmit and especially receive are greater than 100 Kbit/sec.
tcp mss-adjust is one way to address potential issues with fragmentation, which is sometimes an issue when using GRE tunnels. Since GRE is adding additional data in the header the size of the IP packet will be larger than the original packet was. This greater size may cause fragmentation, which increases CPU load and may impact performance.
Rick
Rick
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Need your help.
For?
PS:
BTW, if your IOS supports it, are you using the tcp mss-adjust command?
why my load is 255/255? though the traffic on the interface is not even 1MB.
what is this command for-  tcp mss-adjust?
BW 100 Kbit/sec
Rick
Rick
Disclaimer
Posting
Rick has answered both your question, but just to clarify, if you set the bandwidth (via the bandwidth statement) to match available bandwidth, the loading stats will be correctly computed.  (Tunnels, not being bound to a physical interface, have a "default" bandwidth which seldom matches actual bandwidth.)
For most typical GRE tunnels, you set mss-adjust to MSS (usually 1460) less GRE overhead (24) = 1436.
PS:
You may find this of interest: http://www.cisco.com/en/US/tech/tk827/tk369/technologies_white_paper09186a00800d6979.shtml
