GRE Problem
rmujeeb81
I am facing problem in establishing GRE tunnel.Problem is that both remote routers are able to reach respective tunnel destinations and tunnel interface and protocol are UP but I can't ping P2P ip addresses of tunnel.Kindly guide me
Mujeeb
royalblues
Level 10
Level 10
Can you post the end router configurations
Narayan
nordick26
Try to use some debug commands.
e.g. debug tunnel
If doesn't help, provide more info about you architecture and config, maybe we'll find a "worm" in between.
I would like to add that WAN connections at both locations are DSL based.Routers are coonected with DSL modems over ethernet.When I try to establish GRE over an IPoA connection then it works but when I try over PPPoE in which MTU set at modem is 1492 then GRE doesn't work.
Mujeeb
