GRE Problem
I am facing problem in establishing GRE tunnel.Problem is that both remote routers are able to reach respective tunnel destinations and tunnel interface and protocol are UP but I can't ping P2P ip addresses of tunnel.Kindly guide me
Mujeeb
Re: GRE Problem
Can you post the end router configurations
Narayan
Re: GRE Problem
Try to use some debug commands.
e.g. debug tunnel
If doesn't help, provide more info about you architecture and config, maybe we'll find a "worm" in between.
Re: GRE Problem
I would like to add that WAN connections at both locations are DSL based.Routers are coonected with DSL modems over ethernet.When I try to establish GRE over an IPoA connection then it works but when I try over PPPoE in which MTU set at modem is 1492 then GRE doesn't work.
Mujeeb
Re: GRE Problem
236
