GRE Tunnel and Natting
Dear All
I have a simple set up with a hup GRE/NHRP and a spoke. the spoke has 2 WAN interfaces, f0/0 has a public IP and the GRE tunnel works fine.
The spoke f0/1 gets a private IP from a non cisco VDSL router/modem. On that side the GRE tunnel will not come up. I assume it is because of the NAT/PAT on the VDSL device. I can not figure out what is exacly going on, and what can be done, as I have no control/access over that device..
Thanks ofr your inputs
Best Regards
gb
Re: GRE Tunnel and Natting
Maybe it's just me, but I cannot reconstruct your topology in my head
Do you have a drawing with your topology, or can you make just a basic one and share it with us?
Calin
just one hub and one spoke linked by GRE/NHRP. on he spoke I can test the tunnel on either an interface with a public IP or an interface with a private IP behind a VDSl box. The second option does not work.
Hall of Fame Super Gold
Generally speaking, GRe cannot work behing third-party NAT.
As a workaround, you can congirue GRE over IPsec, that generally work fine with third-party NAT.
It 's also my feeling, I guess it has something to do with NHRP resolution but
I would like to understand the details.
222
