GRE Tunnel
I have 2 GRE Tunnels bulit on my serial interface. One of my tunnels is showing as line protocol down. It is the same on the peer end too. How do i troubleshoot further on this?
Appreciate your help on this.
Navneet
1 ACCEPTED SOLUTION
Re: GRE Tunnel
hi Navneet,
just check it out your tunnel interface with command show interface tunnel x. and check it out the keepalive retries counter next to keepalive set. to make your tunnel up it must be zero or less then the configure time. if it is greater than your set timer then there must be no exchange of keepalive which make your tunnel interface protocol down.
hope this will help you
rate the post if it helps
regards
Devang
Re: GRE Tunnel
Is the destination reachable from both peers?
int tunnel 1
tunnel source IP
tunnel destination IP!!!! can you ping this IP?
Please let us know,
vlad
Re: GRE Tunnel
Thanx for the Reply.
The Tunnel has come back up now. I needed to know a few things with regards to the tunnel troubleshooting.
1) What is the reason for tunnel flaps, even if the interface on which it is built is up and working fine?
2) is there any documentation for GRE and GRE over IPSEC tunnels.
thanking you in advance.
Navneet
Re: GRE Tunnel
Thnx for the Links Devang. It really helped.
Cheers
Navneet
Re: GRE Tunnel
hi Navneet
thanks to you also for giving rating...and with the help of your rating i completed my 100 points.
thanking you again
regards
Devang
276
