Webcast-Catalyst9k
GRE Tunneling
Problem with GRE Tunnel:
I keep getting tunnel 0 up down, and there is no route to the destination, even though I put in a static route.
Message was edited by: kehagen Thanks guys.  Basically I fixed it by fixing the ip connectivity between the two routers.  Your questions triggered me to look in the right direction.
Re: GRE Tunneling
Are you able to ping the tunnel destination and traceroute. post the sh ip route if possible
Hitesh Vinzoda
Pls rate useful posts
Re: GRE Tunneling
can you do an extended ping between the two loopback addresses (i.e. ping 128.8.8.8 with source 129.9.9.9 )? If not, you may need to add a static route for them over the serial interface.
HTH,
Marcel
179
