GRE VRF Point-Point Link Basic Scenario
Hi All
This should be pretty basic I have a scenario where i'm trying to build a vrf GRE tunnel. I'm sure you guys may have seen this problem before. I'm unable to ping across tunnel's 2 WAN link. I took tunnel one out of the vrf to test it and it worked as normal. what do you think? I also tried taking tunnel 2 out of vpn_2 vrf on the CE but still could not ping across the WAN link. Until pinging across the WAN link is possible IPSEC won't work so i need some assisitance.
CE-1#ping vrf vpn_2 204.134.84.26
Sending 5, 100-byte ICMP Echos to 204.134.84.26, timeout is 2 seconds:
Success rate is 0 percent (0/5)
CE-1#
configurations below,
CE-1
hostname CE-1
boot-start-marker
boot-end-marker
enable password cisco
no aaa new-model
memory-size iomem 5
ip cef
ip vrf vpn_2
rd 65000:2
crypto isakmp policy 10
encr aes
hash md5
authentication pre-share
group 2
crypto isakmp key secretkey address 192.168.3.9
crypto isakmp key secretkey address 204.134.83.3
crypto ipsec transform-set TS esp-aes esp-md5-hmac
mode transport
crypto ipsec profile Secure_Tunnel
set transform-set TS
interface Loopback0
ip vrf forwarding vpn_2
ip address 192.168.1.1 255.255.255.255
interface Tunnel1
ip address 204.134.84.21 255.255.255.252
ip mtu 1532
tunnel source 192.168.3.10
tunnel destination 192.168.3.9
tunnel protection ipsec profile Secure_Tunnel
interface Tunnel2
ip address 204.134.84.25 255.255.255.252
ip mtu 1532
tunnel source Loopback0
tunnel destination 204.134.83.3
tunnel vrf vpn_2
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
description *** Link to PE-1 ***
ip address 192.168.3.14 255.255.255.252
no fair-queue
clock rate 2000000
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
description *** Link to PE-1 VRF2 ***
ip address 192.168.3.10 255.255.255.252
no fair-queue
clock rate 2000000
router bgp 65001
no synchronization
bgp log-neighbor-changes
network 192.168.1.1 mask 255.255.255.255
neighbor 192.168.3.9 remote-as 65000
no auto-summary
address-family ipv4 vrf vpn_2
  redistribute connected
  neighbor 192.168.3.13 remote-as 65000
  neighbor 192.168.3.13 activate
  neighbor 192.168.3.13 as-override
  neighbor 204.134.84.26 remote-as 65000
  neighbor 204.134.84.26 activate
  neighbor 204.134.84.26 as-override
  no synchronization
exit-address-family
ip forward-protocol nd
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
PE-1
hostname PE-1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
ip vrf vpn_1
rd 65000:1
route-target export 65000:1
route-target import 65000:1
ip vrf vpn_2
rd 65000:2
route-target export 65000:2
route-target import 65000:2
mpls label protocol ldp
mpls ldp discovery hello interval 1
encr aes
hash md5
group 2
crypto isakmp key secretkey address 192.168.3.10
crypto isakmp key secretkey address 192.168.1.1
mode transport
interface Loopback0
ip address 204.134.83.3 255.255.255.255
interface Tunnel1
ip address 204.134.84.22 255.255.255.252
ip mtu 1500
tunnel source 192.168.3.9
tunnel destination 192.168.3.10
interface Tunnel2
ip address 204.134.84.26 255.255.255.252
ip mtu 1532
tunnel destination 192.168.1.1
tunnel vrf vpn_2
no ip address
shutdown
duplex half
interface Serial1/0
description *** Link to CE-1 ***
ip address 192.168.3.13 255.255.255.252
serial restart-delay 0
interface Serial1/1
ip address 192.168.3.9 255.255.255.252
router ospf 101
log-adjacency-changes
network 204.134.83.0 0.0.0.255 area 0
network 204.134.84.0 0.0.0.255 area 0
router bgp 65000
bgp router-id 204.134.83.3
no bgp default ipv4-unicast
neighbor 204.134.83.1 remote-as 65000
neighbor 204.134.83.1 description PE2
neighbor 204.134.83.1 update-source Loopback0
neighbor 204.134.83.8 remote-as 65000
neighbor 204.134.83.8 description PE3
neighbor 204.134.83.8 update-source Loopback0
address-family vpnv4
  neighbor 204.134.83.1 activate
  neighbor 204.134.83.1 send-community both
  neighbor 204.134.83.8 activate
  neighbor 204.134.83.8 send-community both
exit-address-family
  neighbor 192.168.3.14 remote-as 65001
  neighbor 192.168.3.14 activate
  neighbor 192.168.3.14 as-override
  neighbor 204.134.84.25 remote-as 65001
  neighbor 204.134.84.25 activate
  neighbor 204.134.84.25 as-override
  no synchronization
exit-address-family
address-family ipv4 vrf vpn_1
  neighbor 192.168.3.10 remote-as 65001
  neighbor 192.168.3.10 activate
  neighbor 192.168.3.10 as-override
  no synchronization
exit-address-family
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
PE-1#
339
