Community Member
grounding of a cat 3560
There is no grounding lug on a Cat 3560 switch. If I needed to ground it to the rack what would be the recommended method?
Hall of Fame Super Gold
Re: grounding of a cat 3560
A grounding lug is needed only for devices not rack mounted. If the rack itself is well grounded, all the devices fastened to it are grounded as well.
Totally agree with Paolo, the device chassis itself of the rack mounted devices does this for us (although some rack mounted devices have a grounding lug).
[edit] but i've found that the 3560 has a ground lug:
http://www.cisco.com/en/US/products/ps7077/products_installation_guide_chapter09186a008076393e.html#wp1223523
HTH,
Mohammed Mahmoud.
120
