grouping interfaces
hi there ,
I need to group vlan interfaces in 7609 or in 6509 (hybrid OS).The requirement is if one vlan interface has gone down another should go down.Can this be done in any way.
Im ready to switchover to native IOS too.please guide.
Re: grouping interfaces
Hi Rajiv,
not clear with ur statement "if one vlan interface has gone down another should go down.Can this be done in any way" can u explain?
Hi anandanarayana ,
thanx for the reply.
I have two Vlan interfaces in 6509 configured as below.
int Vlan 600
ip address 172.x.x.x 255.x.x.x
no shut
int vlan 500
ip address 162.x.x.x 255.x.x.x
no shut
See this VLAN interfaces Will be UP & UP when the physical port connected is UP.
For some reasons im creating two backup Vlan interfaces for bothe vlan 500 & 600.
But both these interfaces should go down simeltaneosly in case of one physical port failure in any of the vlans.So my backup group for both these vlans will come up.
Can this be done in anyway?
please guide.
Hi Rajiv,
This is a lot confusing. With the same chasis, it not possible. But if you have 2 6509's or 2 7609's then you can do it using the HSRP or GLBP.
http://www.cisco.com/en/US/tech/tk648/tk362/tk321/tsd_technology_support_sub-protocol_home.html
HTH, Please rate if it does.
-amit singh
Dear Amit,
thanx for the reply.Can this be donw using BVI (im not clear abt bridge-group virtual interface)or in any other way?
Both the interfaces must go down in a single chasis.Please help.
hi ,
instead of doing this backup of ports in l3(vlan interfaces) I can do it in L2 using flex links.
flex links will switch on a l2 port when the physical layer of a particular port is down.
Again there is a problem of grouping interfaces.Can i club Flex link ports?
Please guide.
117
