Webcast-Catalyst9k
Guest traffic
I got Two question, if someone can share idea
(1) How to secure DATA Traffic from Guest VLAN traffic.
(2) How to route Guest VLAN traffic to a router facing Internet
Backbone switch currently got a route to firewall < ip route 0.0.0.0 0.0.0.0 firewall_ip >
how to manipulate guest vlan traffic to another hop than firewall
Data Vlan 10 ; 192.168.1.0 255.255.255.0
Guest vlan 20 ; 192.168.200.0 255.255.255.0
Uplink Backbone to firewall ; vlan id ; 11
backbone ; 10.1.1.1 255.255.255.248
firewall ; 10.1.1.2 255.255.255.248
uplink backbone to DSL_Router ; vlan id 12
backbone : 10.10.10.1 255.255.255.248
DSL_router ; 10.10.10.2 255.255.255.248
CHEERS
JOE
VIP Super Bronze
Guest traffic
Hi Joe,
If your device and your IOS support it and if vlan separation is not enough for you, you can put the guest clan in separate VRF.  The VRF would logically separate the routing table between your date network and your guest network.
Have a look at this link:
http://packetlife.net/blog/2009/apr/30/intro-vrf-lite/
Guest traffic
ACL will be ok
but routing guest traffic to internet didnt work, looks like static entry not working, is route-map needed?
router ospf 1
network 192.168.1.0 0.0.0.255 area 0
network 10.1.1.0 0.0.0.7 area 0
redistribute static subnets
redistribute connected subnets
ip route 0.0.0.0 0.0.0.0 10.1.1.2  ( ASA )
ip route 192.168.100.0 255.255.255.0  192.168.1.200 ( VPN_server )
ip route 192.168.105.0 255.255.255.0 192.168.1.200 (VPN_Server )
ip route 192.168.200.0 255.255.255.0  10.10.10.2
anyone with similar setup working for guest traffic
201
