Guest VLan ASA5505 & AP541N
I'm having an issue with getting a VLAN to work with a ASA5505. I'm QUITE certain the issue is a routing/subnetting issue. I will explain my current configuration.
Cisco ASA 5505
inside interface 192.168.0.3 VLAN 1
guest interface 10.10.10.1 VLAN10
DHCP/DNS Windows 2008 R2 Server 192.168.0.13/255.255.255.0
/192.168.0
.3
Port VLAN 1 Untagged/PVID VLAN10 Tagged
Cisco AP541N
Port VLAN1 Untagged/PVID VLAN10 Tagged
The DHCP Server cannot ping 10.10.10.1 unless I change it's IP address to something on the 10.10.10.0 range. Once I change the DHCP server's IP address to something on the 10.10.10.0 range, I'm able to get my AP to assign an IP address to the wireless client but yet I still do not get internet access. Obviously changing the IP address of the DHCP Server also knocks on the 192.168.0.0 subnet. So all my VLAN tagging and port settings seem right on my switch. I need to change some routing rules in my ASA5505. Please take a look at my configuration. The interface "t1" is my outside interface.
ASA Version 8.2(5)
hostname ASA5505
domain-name lsfiore.com
enable password 30yhcQ8VnFFDaLKh encrypted
passwd 4oVuIVwNDGSflT4W encrypted
names
name 192.168.0.14 fiore-exch
name 192.168.0.21 lsf-tscan
name 192.168.0.5 lsf-wsus
name 192.168.0.15 webfilter
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
switchport access vlan 3
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 10
switchport trunk allowed vlan 10
switchport mode trunk
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.0.3 255.255.255.0
interface Vlan2
nameif t1
security-level 0
ip address 139.55.206.124 255.255.255.248
interface Vlan3
nameif cable
security-level 0
ip address 72.28.195.149 255.255.255.0
interface Vlan10
nameif guests
security-level 100
ip address 10.10.10.1 255.255.255.0
boot system disk0:/asa825-k8.bin
no ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
dns server-group DefaultDNS
same-security-traffic permit inter-interface
object-group network obj-192.168.0.0
object-group network obj-172.172.172.0
object-group network obj-192.168.0.14
object-group network obj-192.168.0.14-01
object-group network obj-192.168.0.14-02
object-group network obj-192.168.0.14-03
object-group network obj-192.168.0.21
object-group network obj-192.168.0.21-01
object-group network obj-192.168.0.21-02
object-group network obj-192.168.0.21-03
object-group network obj-192.168.0.15
object-group network obj-192.168.0.15-01
object-group network obj-192.168.0.7
object-group network obj-192.168.0.5
object-group network obj-192.168.0.5-01
object-group network obj-192.168.0.5-02
object-group network obj-192.168.0.5-03
object-group network obj-192.168.0.5-04
object-group network Exchange
access-list Out-In extended permit tcp 64.18.0.0 255.255.240.0 interface t1 eq smtp
access-list Out-In extended permit tcp any interface t1 eq www
access-list Out-In extended permit tcp any interface t1 eq https
access-list Out-In extended permit icmp any any
access-list Out-In extended permit tcp any host 139.55.206.123 eq www
access-list Out-In extended permit tcp any host 139.55.206.123 eq https
access-list Out-In extended permit tcp any host 139.55.206.123 eq citrix-ica
access-list Out-In extended permit tcp any host 139.55.206.125 eq ftp
access-list Out-In extended permit tcp any host 139.55.206.125 eq 8000
access-list Out-In extended permit tcp any host 139.55.206.125 eq 8280
access-list Out-In extended permit tcp any host 139.55.206.126 eq www
access-list Out-In extended permit tcp any host 139.55.206.126 eq 5222
access-list Out-In extended permit tcp any host 139.55.206.126 eq 5223
access-list Out-In extended permit tcp any host 139.55.206.126 eq 9090
access-list Out-In extended permit tcp any host 139.55.206.126 eq 7777
access-list cable_access_in extended permit tcp 64.18.0.0 255.255.240.0 interface cable eq smtp
access-list cable_access_in extended permit tcp any interface cable eq www
access-list cable_access_in extended permit tcp any interface cable eq https
access-list cable_access_in extended permit icmp any any
access-list cable_access_in extended permit tcp any host 72.28.195.148 eq www
access-list cable_access_in extended permit tcp any host 72.28.195.148 eq https
access-list cable_access_in extended permit tcp any host 72.28.195.148 eq citrix-ica
access-list cable_access_in extended permit tcp any host 72.28.195.150 eq ftp
access-list cable_access_in extended permit tcp any host 72.28.195.150 eq 8000
access-list cable_access_in extended permit tcp any host 72.28.195.150 eq 8280
access-list cable_access_in extended permit tcp any host 72.28.195.151 eq www
access-list cable_access_in extended permit tcp any host 72.28.195.151 eq 5222
access-list cable_access_in extended permit tcp any host 72.28.195.151 eq 5223
access-list cable_access_in extended permit tcp any host 72.28.195.151 eq 9090
access-list cable_access_in extended permit tcp any host 72.28.195.151 eq 7777
access-list inside_nat0_outbound_1 extended permit ip any any
access-list inside_nat0_outbound_1 extended permit ip 10.10.10.0 255.255.255.0 any
access-list inside_nat0_outbound_1 extended permit ip 192.168.0.0 255.255.255.0 any
access-list inside_nat0_outbound extended permit ip any 172.172.172.0 255.255.255.0
access-list guests_nat0_outbound_1 extended permit ip any any
access-list guests_nat0_outbound_1 extended permit ip 10.10.10.0 255.255.255.0 any
access-list guests_nat0_outbound extended permit ip any 172.172.172.0 255.255.255.0
pager lines 24
logging enable
logging monitor debugging
logging buffered errors
logging trap errors
logging asdm debugging
logging host inside lsf-wsus
mtu inside 1500
mtu t1 1500
mtu cable 1500
mtu guests 1500
ip local pool vpnpool 172.172.172.100-172.172.17
2.199 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-645-206.bin
no asdm history enable
arp timeout 14400
global (t1) 1 interface
global (cable) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 192.168.0.0 255.255.255.0
nat (guests) 0 access-list guests_nat0_outbound
nat (guests) 1 10.10.10.0 255.255.255.0
static (inside,t1) tcp interface smtp fiore-exch smtp netmask 255.255.255.255 dns
static (inside,t1) tcp interface www fiore-exch www netmask 255.255.255.255
static (inside,t1) tcp interface https fiore-exch https netmask 255.255.255.255
static (inside,t1) tcp 139.55.206.123 www lsf-tscan www netmask 255.255.255.255
static (inside,t1) tcp 139.55.206.123 https lsf-tscan https netmask 255.255.255.255
static (inside,t1) tcp 139.55.206.123 citrix-ica lsf-tscan citrix-ica netmask 255.255.255.255
static (inside,t1) tcp 139.55.206.123 2598 lsf-tscan 2598 netmask 255.255.255.255
static (inside,t1) tcp 139.55.206.125 8000 webfilter 8000 netmask 255.255.255.255
static (inside,t1) tcp 139.55.206.125 8280 webfilter 8280 netmask 255.255.255.255
static (inside,t1) tcp 139.55.206.126 www lsf-wsus www netmask 255.255.255.255
static (inside,t1) tcp 139.55.206.126 5222 lsf-wsus 5222 netmask 255.255.255.255
static (inside,t1) tcp 139.55.206.126 5223 lsf-wsus 5223 netmask 255.255.255.255
static (inside,t1) tcp 139.55.206.126 7777 lsf-wsus 7777 netmask 255.255.255.255
static (inside,t1) tcp 139.55.206.126 9090 lsf-wsus 9090 netmask 255.255.255.255
static (inside,cable) tcp interface smtp fiore-exch smtp netmask 255.255.255.255 dns
static (inside,cable) tcp interface www fiore-exch www netmask 255.255.255.255
static (inside,cable) tcp interface https fiore-exch https netmask 255.255.255.255
static (inside,cable) tcp 72.28.195.148 www lsf-tscan www netmask 255.255.255.255
static (inside,cable) tcp 72.28.195.148 https lsf-tscan https netmask 255.255.255.255
static (inside,cable) tcp 72.28.195.148 citrix-ica lsf-tscan citrix-ica netmask 255.255.255.255
static (inside,cable) tcp 72.28.195.148 2598 lsf-tscan 2598 netmask 255.255.255.255
static (inside,cable) tcp 72.28.195.150 8000 webfilter 8000 netmask 255.255.255.255
static (inside,cable) tcp 72.28.195.150 8280 webfilter 8280 netmask 255.255.255.255
static (inside,cable) tcp 72.28.195.151 www lsf-wsus www netmask 255.255.255.255
static (inside,cable) tcp 72.28.195.151 5222 lsf-wsus 5222 netmask 255.255.255.255
static (inside,cable) tcp 72.28.195.151 5223 lsf-wsus 5223 netmask 255.255.255.255
static (inside,cable) tcp 72.28.195.151 7777 lsf-wsus 7777 netmask 255.255.255.255
static (inside,cable) tcp 72.28.195.151 9090 lsf-wsus 9090 netmask 255.255.255.255
access-group Out-In in interface t1
access-group cable_access_in in interface cable
route t1 0.0.0.0 0.0.0.0 139.55.206.121 1
route cable 0.0.0.0 0.0.0.0 72.28.195.1 2
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-reco
rd DfltAccessPolicy
aaa-server RADIUS protocol radius
aaa-server RADIUS (inside) host 192.168.0.13
key *****
radius-common-pw *****
aaa-server RADIUS (inside) host 192.168.0.10
key *****
aaa authentication ssh console LOCAL
http server enable 444
http 192.168.0.0 255.255.255.0 inside
http 0.0.0.0 0.0.0.0 guests
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map outside_dyn_map 10 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map outside_dyn_map 10 set security-association lifetime seconds 86400
crypto dynamic-map outside_dyn_map 30 set pfs group1
crypto dynamic-map inside_dyn_map 20 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 10 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface t1
crypto map inside_map 65535 ipsec-isakmp dynamic inside_dyn_map
crypto map inside_map interface inside
crypto map cable_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map cable_map interface cable
crypto isakmp enable t1
crypto isakmp enable cable
crypto isakmp policy 10
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet 192.168.0.0 255.255.255.0 inside
telnet timeout 30
ssh timeout 30
console timeout 0
management-access inside
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 192.43.244.18 source t1
ntp server 129.6.15.29 source t1
ntp server 129.6.15.28 source t1
webvpn
enable t1
group-policy LSF internal
group-policy LSF attributes
dns-server value 192.168.0.13 192.168.0.10
vpn-tunnel-protocol IPSec
default-domain value lsfiore.com
username Mike password nsbrPcayUUh9BZXK encrypted privilege 15
username administrator password ErafdxCnVlZ7bMwk encrypted
username agunnett password KwrpFR94EMHbOwAx encrypted privilege 15
username winningtech password etFobu8SZ3vQgwhE encrypted privilege 15
tunnel-group LSF type remote-access
tunnel-group LSF general-attributes
address-pool vpnpool
authentication-server-grou
p RADIUS
default-group-policy LSF
tunnel-group LSF ipsec-attributes
pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect ftp
inspect esmtp
inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http
https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:c176010e5d6
2e8150b82f
089f3a5577
a
: end
Everyone's tags (3)
1017
