Guest VLAN single Internet Connection via DHCP not routing
I have a 1921 Router connected to a DSL Internet router using DHCP
We have this setup with a Dynamic VPN to a Cisco ASA for a small remote office.
This is working well and no issue here
We want to setup a Guest_LAN on the same Router, and have that traffic goto through the same internet pipe.
DHCP is working and the separate vlan is working just we are unable to access the Internet
ip dhcp excluded-address 172.16.54.250 172.16.54.254
ip dhcp pool Guest
 network 172.16.54.0 255.255.255.0
 default-router 172.16.54.254
 dns-server 8.8.8.8 8.8.4.4
 domain-name nufarmguest.com
interface GigabitEthernet0/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description ISP_Connection
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 no ip route-cache
 ip tcp adjust-mss 1300
 duplex auto
 speed auto
 crypto map NAFTA_VPN
interface GigabitEthernet0/1/0
 switchport access vlan 54
 no ip address
interface GigabitEthernet0/1/1
 no ip address
interface GigabitEthernet0/1/2
 no ip address
interface GigabitEthernet0/1/3
 no ip address
interface GigabitEthernet0/1/4
 no ip address
interface GigabitEthernet0/1/5
 no ip address
interface GigabitEthernet0/1/6
 no ip address
interface GigabitEthernet0/1/7
 switchport access vlan 999
 no ip address
interface Vlan1
 no ip address
 shutdown
interface Vlan54
 ip address 10.1.54.254 255.255.255.0
 ip helper-address 10.1.122.58
 ip helper-address 10.1.122.79
 ip nat inside
interface Vlan999
 ip address 172.16.54.254 255.255.255.0
 ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map GUEST_MATCH interface GigabitEthernet0/1 overload
ip nat inside source route-map VPN_MATCH interface GigabitEthernet0/1 overload
ip access-list extended GUEST_MATCH
 permit ip 172.16.54.0 0.0.0.255 any
ip access-list extended NAT_OVERLOAD
 permit ip any any
ip access-list extended VPN_MATCH
 permit ip 10.1.54.0 0.0.0.255 10.0.0.0 0.255.255.255
ip access-list extended VPN_NONAT
 deny   ip 10.1.54.0 0.0.0.255 10.0.0.0 0.255.255.255
 permit ip any any
route-map NONAT permit 10
 match ip address VPN_NONAT
1 REPLY
Try adding the Guest subnet
Try adding the Guest subnet to the VPN_NONAT ACL.
149
