Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
H323 over Zone Based Fire Wall
I am facing an issue for Video Conf conneciton over SR520 with Zone based-firewall.
I can call out from inside to outside but cannot recieve call from outside.
below shows what i have done for this... am i missing any?
appreciate if some one can help me. any advice will helpfull! Thanks much!
what i have done is :
1) add NAT translation
ip nat inside source static 172.16.92.15 xxx.xxx.xxx.xxx
2) create an access-list with following ports to allow the traffic.
ip access-list extended TANDBERG
permit tcp any any eq 389
permit tcp any any eq www
permit tcp any any eq 443
permit tcp any any eq 1720
permit tcp any any gt 1023
permit udp any any gt 1023
3) create a class-map with following protocols with  "access-group name TANDBERG" as above.
class-map type inspect match-any SDM-Voice-permit
match protocol sip
match protocol h323
match protocol icmp
match protocol telnet
match protocol ssh
match protocol skinny
match protocol h225ras
match protocol h323-annexe
match protocol h323-nxg
match access-group name TANDBERG
4) added class-map to policy-map as below which is for inside > outside.
policy-map type inspect sdm-inspect
class type inspect SDM-Voice-permit           <<<<<<<<<<<<<<<<<<
  inspect
class type inspect sdm-cls-insp-traffic
  inspect
class type inspect sdm-protocol-http
  inspect z1-z2-pmap
class type inspect sdm-invalid-src
  inspect
class type inspect PPTP-Pass-Through-Traffic
  pass
class type inspect All-Traffic
  inspect
class class-default
  pass
policy-map type inspect sdm-inspect-voip-in
  inspect
  pass
class type inspect SDM-inspect-staticnat-in
  inspect
class type inspect L2L_VPN_10.188.18.0_23
  inspect
class class-default
  drop
zone security out-zone
zone security in-zone
zone security pptp
zone-pair security sdm-zp-self-out source self destination out-zone
service-policy type inspect sdm-permit-icmpreply
zone-pair security sdm-zp-out-in source out-zone destination in-zone
service-policy type inspect sdm-inspect-voip-in
zone-pair security sdm-zp-out-self source out-zone destination self
zone-pair security sdm-zp-in-out source in-zone destination out-zone
zone-pair security pptp-in source pptp destination in-zone
service-policy type inspect PPTP-In-Policy
zone-pair security pptp-out source pptp destination out-zone
5) also added for outside > inside
  inspect
  pass
  inspect
  inspect
class class-default
  drop
zone security pptp
zone-pair security sdm-zp-out-in source out-zone destination in-zone                <<<<<<<<<<<<<<<<<<<
zone-pair security sdm-zp-in-out source in-zone destination out-zone              <<<<<<<<<<<<<<<<<<
Everyone's tags (7)
316
