H323 Slow Start config....?????
Hi.
i have configured a dial peer on as5300 (IOS version 12.3 (15)) with slow start using
voice class h323
call start slow
but when i check running configuration i dont see "voice class h323" in the dial peer neither call is established with slow start.i have also tried to configure
voice service voip
h323 call start slow
kindly advise how i can configure the dial peer with slow start.
1 ACCEPTED SOLUTION
Blue
Re: H323 Slow Start config....?????
Did you apply the voice class to the peer? The voice service command should apply slow start globally so you won't see any change to the peer if you do it that way.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a0080080b20.html#wp1147738
Configuring Slow Connect for VoIP Globally
To make an H.323 gateway backward-compatible with a destination gateway, use the following commands beginning in global configuration mode. This procedure is optional and selects Slow Connect globally for all VoIP services.
Command
Purpose
Step 1
Router(config)# voice service voip
Enters voice-service configuration mode for VoIP services.
Step 2
Router(conf-voi-serv)# h323 call start slow
Forces the H.323 gateway to use Slow Connect procedures.
Note To restore the default of Fast Connect, use the h323 call start fast command.
Note The previous procedure selects Slow Connect globally for all VoIP calls. To change the type of connect procedures for calls associated with a specific dial peer, use the following procedure:
Configuring Slow Connect for a Specific Dial Peer
Note This procedure is optional and selects Slow Connect for a specific VoIP dial peer.
To make an H.323 gateway backward-compatible with a destination gateway, use the following commands beginning in global configuration mode:
Command
Purpose
Step 1
Router(config)# voice class h323 tag
Enters voice-class configuration mode and creates a voice class for H.323 attributes.
Step 2
Router(config-class)# call start slow
or
Router(config-class)# call start system
Forces the H.323 gateway to use Slow Connect procedures. The default is slow. The keyword system causes the H.323 gateway to use the connect procedure that is configured in the voice-service configuration (see Configuring Slow Connect for VoIP Globally).
Note If you require Fast Connect for a specific dial peer, use the call start fast command to restore the default when configuring the Slow Connect for VoIP globally.
Step 3
Router(config-class)# exit
Exits voice-class configuration mode and returns to global configuration mode.
Step 4
Router(config)# dial-peer voice number voip
Enters dial-peer configuration mode for the VoIP dial peer.
Step 5
Router(config-dial-peer)# voice-class h323 tag
Assigns the voice class attributes to the dial peer, including the H.323 connect procedure that was selected in Step 2.
Please rate helpful posts.
1 REPLY
Blue
Command
Purpose
Step 1
Step 2
Command
Purpose
Step 1
Step 2
or
Step 3
Step 4
Step 5
1990
