hardware choices???
I am in search of a router that is expandable to 12 WAN links and 4 ethernet, any suggestions?
Thanks, any help would be appreciated
Hall of Fame Super Gold
Re: hardware choices???
Which type/speed the wan links you need ?
64k serial
serial link 64K
you can use a 2811 with nm-16a/s, and hwic-4esw.
Or 3 x hwic-4T instead of nm-16a/s, if you plan to upgrade the links the higher speeds. In this case, a 2801 would suffice.
103
