HELP! 1921 with Internet Static IP Won't Access Internet
Well here I am again needing your help.  I have the same 1921 router that I am trying to install at a facility with a Static IP address and Static DNS information to get on the internet and I cannot get the 1921 to access the internet!
Please help!
Here is my config:
Building configuration...
Current configuration : 4072 bytes
! Last configuration change at 09:51:57 Chicago Sun Feb 26 2012 by fbcpekin
! NVRAM config last updated at 09:51:58 Chicago Sun Feb 26 2012 by fbcpekin
version 15.1
hostname Router
boot-start-marker
boot-end-marker
no logging buffered
no aaa new-model
clock timezone Chicago -6 0
clock summer-time Chicago date Apr 6 2003 2:00 Oct 26 2003 2:00
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.9
ip dhcp excluded-address 192.168.1.101 192.168.1.254
ip dhcp pool FBCPEKIN
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 198.88.216.2 198.88.216.3
ip name-server 198.88.216.2
ip name-server 198.88.216.3
crypto pki trustpoint TP-self-signed-3546398486
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3546398486
revocation-check none
rsakeypair TP-self-signed-3546398486
crypto pki certificate chain TP-self-signed-3546398486
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33353436 33393834 3836301E 170D3132 30323139 30333035
  35365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 35343633
  39383438 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B860 89AC13B6 CA531BD3 74C101FE 61B692F8 489F752F 446A67F8 585C79DB
  0903ECBF ABDDD96C 48E3A722 079C2C75 4DF10411 4E324ABC 91525659 FF0DF5ED
  5D402F3B E58149BC CCC59CC2 AE3791B8 E01D1058 D4C138CA 9CC5DF1D FF6C4982
  D87555F2 98E3BE0E 9AD0EBAD 0046088F 975153CE 831448DB C980E871 CE210F11
  4BB10203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14684EFE D8F89D07 8BEB59C1 2A0B4EB6 4381C6E2 F1301D06
  03551D0E 04160414 684EFED8 F89D078B EB59C12A 0B4EB643 81C6E2F1 300D0609
  2A864886 F70D0101 05050003 81810077 E7BF3077 00BE1B82 753CB4FA 21EB3050
  9F69D5B2 D1DD0C25 064BEACF A4CFBB15 A3387FED 83FBFB45 E2B29096 93F1E032
  9AC08D09 2619A6C7 40F0983F 27F42A33 F4EC689E BA86B6D5 8DF0AC43 B4ABBF56
  A369433F 51F97571 4F66CD0E A8021C43 43072C28 E5295F7A E3FEB3C6 D5B046C9
  2B776313 42FC7517 F98FF7A3 E1B420
            quit
license udi pid CISCO1921/K9 sn FTX155283EJ
license boot module c1900 technology-package securityk9
username fbcpekin privilege 15 secret 5 $1$a8TV$EO9ocWsA1p8R/SYt.a0lZ/
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description $ETH-WAN$
ip address 207.152.69.137 255.255.255.0
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool FBCPEKIN 192.168.1.10 192.168.1.250 netmask 255.255.255.0
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
ip access-list extended FBC1
remark CCP_ACL Category=2
permit ip any any
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet ssh
transport output telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
1 ACCEPTED SOLUTION
Hi Wesley,
youre static route (ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1) should pointing the next-hop which supposed to be
207.152.69.xxx.
Cheers,
MT
Hi Wesley,
207.152.69.xxx.
Cheers,
MT
Hall of Fame Super Silver
Wesley
I agree with MT that the problem is most likely in your default route. When a static route just points to an Ethernet interface then the router must send arp requests for every remote destination. And this static route can work only if the upstream router supports proxy arp. And increasingly providers are not supporting proxy arp because of the security implications. If you determine the address of the provider router and use that in your static route then things should work much better.
Rick
557
