10-12-2013 10:28 AM - edited 03-04-2019 09:18 PM
hello,
can you plz tell me how i can adv just somes network,
see plz attachement,
Best regards,
Solved! Go to Solution.
10-12-2013 05:02 PM
Again, in my previous post, I stated that you can advertise anything your router knows about. If it's in the routing table, you can choose to advertise or not. It doesn't matter whether you have a default static route or not. If it's in your table, then you can choose to advertise it. I'm not asking the "same information." See below:
"Customer"
R1#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
172.13.0.0/24 is subnetted, 1 subnets
C 172.13.0.0 is directly connected, FastEthernet0/0
172.16.0.0/24 is subnetted, 4 subnets
B 172.16.12.0 [20/0] via 172.13.0.3, 00:01:07
B 172.16.8.0 [20/0] via 172.13.0.3, 00:01:07
B 172.16.10.0 [20/0] via 172.13.0.3, 00:01:07
B 172.16.123.0 [20/0] via 172.13.0.3, 00:01:07
150.100.0.0/24 is subnetted, 1 subnets
C 150.100.200.0 is directly connected, Loopback1
YOUR Router:
ip route 0.0.0.0 0.0.0.0 172.13.0.1
ip route 172.16.8.0 255.255.255.0 3.3.3.5
ip route 172.16.10.0 255.255.255.0 3.3.3.5
ip route 172.16.12.0 255.255.255.0 3.3.3.5
ip route 172.16.123.0 255.255.255.0 3.3.3.5
R3(config-if)#do sh ip access-list 10
Standard IP access list 10
10 permit 172.16.8.0, wildcard bits 0.0.0.255 (2 matches)
20 permit 172.16.10.0, wildcard bits 0.0.0.255 (2 matches)
30 permit 172.16.12.0, wildcard bits 0.0.0.255 (2 matches)
40 permit 172.16.123.0, wildcard bits 0.0.0.255 (2 matches)
R3(config-if)#do sh run | s route-map
redistribute static route-map Static
route-map Static permit 10
match ip address 10
R3(config-if)#do sh run | s router bgp
router bgp 3
no synchronization
bgp log-neighbor-changes
neighbor 172.13.0.1 remote-as 1
no auto-summary
R3(config-if)#do sh ip bgp rege ^$
BGP table version is 11, local router ID is 3.3.3.3
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 172.16.8.0/24 3.3.3.5 0 32768 ?
*> 172.16.10.0/24 3.3.3.5 0 32768 ?
*> 172.16.12.0/24 3.3.3.5 0 32768 ?
*> 172.16.123.0/24 3.3.3.5 0 32768 ?
R3(config-if)#
So, again, your route-map looks fine. If you want further help, please post the following:
show ip route static
sh ip bgp summar
sh ip bgp rege ^$
Your default route will not affect advertising other static routes out regardless of those routes being covered by the default.
HTH,
John
*** Please rate all useful posts ***
10-12-2013 10:37 AM
If you have those routes directly connected on the router, you can just advertise what you want with the network command and not include the subnets you don't want advertised. If you're learning those routes from somewhere else, BGP will automatically advertise them out if you don't have a distribute list or route-map controlling their advertisement.
It looks like your route-map will work fine to me...
HTH,
John
10-12-2013 10:49 AM
hi,with this config,my table routing :
*> 0.0.0.0 X.X.X.X 0 0 64520 i
*> 192.168.10.0 X.X.X.X 0 0 64520 i
despite the route-map with which acl allowing just some networks, I can ping all the network list (including They Will not to be annonced)
10-12-2013 10:53 AM
Are those 172. routes in your routing table? Can you post "show ip route"?
HTH,
John
10-12-2013 11:04 AM
R2#sh ip route
Gateway of last resort is 192.168.87.10 to network 0.0.0.0
10.0.0.0/24 is subnetted, 1 subnets
S 10.10.10.0 [1/0] via 192.168.87.10
11.0.0.0/24 is subnetted, 1 subnets
S 11.11.11.0 [1/0] via 192.168.87.10
12.0.0.0/24 is subnetted, 1 subnets
S 12.12.12.0 [1/0] via 192.168.87.10
172.16.0.0/16 is subnetted, 1 subnets
S 172.16.31.0 [1/0] via 192.168.87.10
172.18.0.0/16 is subnetted, 1 subnets
S 172.18.103.0 [1/0] via 192.168.87.10
172.19.0.0/16 is subnetted, 1 subnets
S 172.19.238.0 [1/0] via 192.168.87.10
S 192.168.64.0/24 [1/0] via 192.168.87.10
C 10.118.129.0 is directly connected, FastEthernet0/1
C 192.168.87.0/24 is directly connected, FastEthernet0/0
S* 0.0.0.0/0 [1/0] via 192.168.87.10
10-12-2013 11:10 AM
When you applied the route-map, did you clear your bgp sessions? Try "clear ip bgp * soft" and see if that helps. After doing that, please post "show ip bgp regex ^$"
HTH,
John
10-12-2013 01:46 PM
I do not know why you are asking the same information,
my request is simple, I have a default static route, I just want to publish some network although obviously that are part of the overall route ip route 0.0.0.0 0.0.0.0 XXXX
Sincerely,
10-12-2013 05:02 PM
"Customer"
R1#sh ip route
YOUR Router:
match ip address 10
router bgp 3
no synchronization
no auto-summary
R3(config-if)#
sh ip bgp summar
sh ip bgp rege ^$
HTH,
John
10-14-2013 02:57 PM
Conclusion: I am a lab in this direction, and I can confirm what you said, in fact, I thought the router will understand when I
declare (to enable network ACL) of a network in an ACL XXXX and it is released from the default route, but this is wrong because it is impératievment to declare as ip route XXXX [mask] [destination]
Thank you !
