05-28-2007 07:07 AM - edited 03-03-2019 05:10 PM
r31 get route for r32. from "sh ip bgp" but r31 think the route (10.0.0.0), is igbp route and dont advertising to R1. How to fix the problem? The attachment is diagram.
I use "no sy" under each router bgp protocol
R31 "sh ip bgp"
* i9.0.0.0,192.168.103.1 ,0,100,0,1 9 i
192.168.103.1 is R2 ip address.
05-28-2007 07:18 AM
If we are supposed to help you, you need to post the bgp config on at least r31.
You migth have prefix or as-path filtering output from r31 or input on r1. It could be the case ?
Also, post a show ip bgp nei x.x.x.x adver, on r31.
BR,
Bjornarsb
05-28-2007 07:26 AM
I fix the problem.........
this is next-hop problem.
just add "next-hop-self".
