help me configure NAT from outside to inside
hy,
i have in my LAN networl a server that i want to access it from outside.
i have configued the NAT to support this access, but it does not work.
i send you configuration of the router :
Router#sh run
Building configuration...
Current configuration : 1108 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
enable secret xxx
no aaa new-model
ip cef
voice-card 0
archive
log config
hidekeys
interface FastEthernet0/0
ip address 10.100.100.17 255.255.254.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 2338
ip address 84.x.x.172 255.255.255.248
ip nat outside
ip route 0.0.0.0 0.0.0.0 84.16.28.169
ip http server
ip nat inside source list 1 interface FastEthernet0/1.1 overload
ip nat inside source static tcp 10.100.100.10 443 84.16.28.172 443 extendable
access-list 1 permit any
control-plane
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
password test
login
scheduler allocate 20000 1000
end
Router#
1 REPLY
Re: help me configure NAT from outside to inside
I have noticed that your nat outside interface belongs to a VLAN 2338, make sure that
the next hop and outside part of the network can reach this interface.
in a lab environment i reproduced almost the same topology
on NAT device:
ip address 84.16.28.172 255.255.255.0
ip nat outside
duplex full
interface FastEthernet1/0
ip address 10.100.100.101 255.255.255.0
ip nat inside
duplex full
speed auto
ip nat source list 1 interface FastEthernet0/0
ip nat source static tcp 10.100.100.10 443 84.16.28.172 443 extendable
ip nat inside source static 10.100.100.100 84.16.28.172
ip route 0.0.0.0 0.0.0.0 84.16.28.172
Take a look at the enclosed document for the results.
97
