02-18-2012 08:53 PM - edited 03-04-2019 03:19 PM
Please see the report from Cisco.
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
This says an ISR G2 3945 can achieve 502.78 Mbits when CEF fast switching. Is this per port or total for the whole box? Since the router will hold dozens of switch ports and several gig routed ports I don't understand what this half gig switching speed means. Thank you.
Solved! Go to Solution.
02-18-2012 09:09 PM
This is the entire CHASSIS or "box" as you'd call it.
Another thing to consider, the value is expressed in HALF duplex and without any encryption.
If you want FULL duplex then halve the value. If you want full duplex and with encryption then take the full value and divide it by a factor of four (4).
If you take the value of 502.78 and divide it by four (4) this gives you 125.7 Mbps. How do you expect 125.7 Mbps of traffic to pass through a 100 Mbps interface? You need to have a 1000 Mbps (or 1 Gig) interface.
02-18-2012 09:09 PM
02-18-2012 09:16 PM
Agree with Leo.
Adding to that please note that CEf switching here is not the regular L2 switching within same VLAN. This is basically routing between different subnets which is done in HW. All routers are limited in routing performance that is why we see 0.5GB number here. Though considering that router is used to connect to WAN where speeds are still much smaller that is a good throughput.
Nik
02-21-2012 08:52 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
"All routers are limited in routing performance . . . "
Doesn't Cisco sell the 7600 and CRS1/3 series as "routers" . . . their routing performance isn't too limited, maybe not all?
02-22-2012 02:13 AM
But some routers are more routers than others.
02-20-2012 02:03 PM
Thanks Tod.
