05-14-2007 01:29 AM - edited 03-03-2019 04:57 PM
in a sad manner, i found a software that crackes the encrypted cisco passowrd for router and pix firewall, called cain & abel
so help me to fix this problem in IOS
05-14-2007 01:44 AM
Use the secret password (MD5) instead, which can't be cracked.
Router(config)#username test secret test
Router(config)#enable secret test
When displayed on a cisco router its like this:
username test secret 5 $1$UuqK$HKduW.7M7o6l1rJ8dUs3r1
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
05-14-2007 01:59 AM
We can encrypt Password in Two ways
1, Manual encryption
Router (config) #enable password XXXX
Router (config) #service password encryption
If you give this command it will be encrypted by MD7 algorithm and we can break easily by using 3rd party software?s
2, Automatic encryption
Router (config) #enable secret XXXX
It will be encrypted by MD5 and difficult to break it
