Community Member
help needed Cisco asa 5505
I get the message trying to access owa on a Small Business server 2011:
TCP access denied by ACL from 86.xx.xx.xx/28860 to outside 62.xx.xx.xx/443
I am not (yet) an experienced user. Can somebody give me a hint?
Below the config
Thanks!
: Saved
ASA Version 8.3(1)
hostname asa2
enable password i9.yhWTfK7AnxZ5r encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 192.168.131.8 sbs
interface Vlan1
nameif inside
security-level 100
ip address 192.168.131.152 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address xx.xx.xx.5 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network NETWORK_OBJ_192.168.131.128_25
subnet 192.168.131.128 255.255.255.128
object network exchange
host 192.168.131.8
object service https
service tcp source eq https destination eq https
object-group service owa tcp
port-object eq https
access-list outside_access_in extended permit ip any any
access-list outside_access_in extended permit object https any interface outside
access-list outside_access_in extended permit tcp any interface outside eq smtp
access-list outside_access_in remark Allow SMTP traffic
access-list outside_access_in remark Allow SSL-OWA-RWA Traffic
access-list outside_access_in extended permit tcp any interface outside eq https
access-list outside_access_in remark Allow SharePoint traffic
access-list outside_access_in extended permit tcp any interface outside eq 987
access-list inside_access_out extended permit ip any any
access-list global_access extended permit ip any any inactive
access-list inside_access_in extended permit ip any any
access-list outside_access_out extended permit ip any any
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
ip local pool mediostpool 192.168.131.180-192.168.131.199 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) source dynamic any interface
nat (inside,outside) dynamic interface
nat (inside,outside) static interface service tcp https https
access-group outside_access_in in interface outside
access-group outside_access_out out interface outside
access-group inside_access_in in interface inside
access-group inside_access_out out interface inside
access-group global_access global
route outside 0.0.0.0 0.0.0.0 xx.xx.xx.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.131.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto  dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set  ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5  ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA  ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.131.156-192.168.131.187 inside
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy mediostvpn internal
group-policy mediostvpn attributes
vpn-tunnel-protocol IPSec
username Anton password jRVOT3qxuT/xdrp5 encrypted privilege 0
username Anton attributes
vpn-group-policy vpn
tunnel-group vpn type remote-access
tunnel-group vpn general-attributes
address-pool pool
default-group-policy vpn
tunnel-group vpn ipsec-attributes
pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect icmp
service-policy global_policy global
prompt hostname context
Cryptochecksum:6f543b73d5b1a3c82e794f228364edd0
: end
asdm location sbs 255.255.255.255 inside
1 ACCEPTED SOLUTION
Hi there,
If your SBS's default-gateway address is: 192.168.131.8, then any internet traffic coming in to SBS server will be sent to its default-gateway, i.e. 192.168.131.8, therefore you must change its default-gateway to ASA2's
If ASA2's outside interface is connected to Cisco878 router (I assume Cisco878 is routing), then you must create a static nat on your Cisco878 router as well, otherwise change your Cisco878 router and replace with Zyxel-modem instead, which will ease up your administration.
thanks
Rizwan Rafeek
Re: help needed Cisco asa 5505
Please remove these highlighted lines, because ASA version 8.3 does not use public address on the acl, but rather real-ip for static nat.
Now please copy this instead.
access-list outside_access_in extended permit tcp any host 192.168.131.8 eq https
access-list outside_access_in extended permit tcp any host 192.168.131.8 eq smtp
access-list outside_access_in extended permit tcp any host 192.168.131.8 eq 987
And you do same static-nat for other services you want to static nat to, for their respective ports.
Hope that helps.
thanks
Rizwan Rafeek
Community Member
Hi, I followed your instructions but it does not make a difference. Still get
TCP access denied by ACL from 86.xx.xx.xx/25434 to outside 62.xx.xx.xx/443
Any suggestions left? Below the config which is active now (to make sure that i did not make a mistake following your instructions)
Thanks!
: Saved
ASA Version 8.3(1)
hostname asa2
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
host 192.168.131.8
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
arp timeout 14400
http server enable
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
group-policy vpn internal
group-policy vpn attributes
address-pool pool
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
Cryptochecksum:53e129163a76121621f3ecb761a94331
: end
Community Member
Sorry i found what was wrong the NAT sequence (i think an beginner mistake ).
Now i get:
Teardown TCP connection 75321 for outside:xx.xx.xx.218/25990 to inside:sbs/443 duration 0:00:30 bytes 0 SYN Timeout
and i am not getting the OWA inlogscreen.... Any suggestions left.
Please remove this highlighted line, as it overlaps.
the above overlaps with below.
Please remove this highlighted line below, as it defeats the purpose of the firewall.
Please copy the static nat below for smtp traffic and http, https
nat (inside,outside) static interface service tcp http http
nat (inside,outside) static interface service tcp smtp smtp
FYI...
You do not need these lines at all.
Please follow the link below, if you like to reference Cisco doc.
https://supportforums.cisco.com/docs/DOC-9129
http://www.cisco.com/en/US/docs/security/asa/asa83/configuration/guide/nat_objects.html
Let me know, if this helps.
thakns
Community Member
Hi Rizwan,
I added this NAT rule
object network server2
host 192.168.131.8
nat (inside,outside) static interface service tcp 443 443
and try to cleanup the code.
But i still get the
Teardown TCP connection 81475 for outside:xx.xx.x.xx5/38666 to inside:192.168.131.8/443 duration 0:00:30 bytes 0 SYN Timeout
Could it be the reason that i have 2 asa's in the network and that the small business server not have this asa as standard gateway?
Thanks!
For your info the code below
: Saved
ASA Version 8.3(1)
hostname asa2
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ftp mode passive
same-security-traffic permit intra-interface
host 192.168.181.8
host 192.168.131.8
access-list outside_access_in extended permit tcp any object server2 eq https
access-list outside_access_in extended permit tcp any object server2 eq smtp
access-list outside_access_in extended permit tcp any object server2 eq 987
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
ip local pool pool 192.168.131.180-192.168.131.199 mask 255.255.255.0
arp timeout 14400
http server enable
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
address-pool pool
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
Cryptochecksum:490c669c4f87ad54edd0c4da0170d052
: end
host 192.168.181.8
"Could  it be the reason that i have 2 asa's in the network and that the  small  business server not have this asa as standard gateway?"
In a large enterprise environment, no devices (i.e. servers) use firewall as a default-gateway address, as long as inter-vlan traffic is routed by a layer3 switch or router.
Please post a diagram of your physical connection and the devices in between and device type (i.e. layer2 or layer3) and default gateway pointed on devices (switches) and servers.
For third time I am telling you do not need these lines at all.
thanks.
Community Member
Hi Rizwan,
It is just for a small company having currently 2 internetlines. The second asa (asa2) is added to the network and that is the one i am trying to configure. When all items working smootly the asa1 will be deleted from the network. See the network schema attached.
Hi there,
thanks
Rizwan Rafeek
Community Member
Thank you Rizwan. I will change the default gateway tommorrow and let you know if it worked out.
Arnold
Hi Arnold,
Please update the thread, in any case if this issue has been resolved please rate helpful post.
thanks
Rizwan Rafeek
Community Member
Hi Rizwan,
I checked it yesterday evening and changing the default gateway solved the problem. Thanks for your help and patience!
regards,
2651
