Webcast-Catalyst9k
Help summarising routes
I have been using GNS3 to help be refresh my mind on redistributing routes between different routing protocols, here is the topology:
Routers R5, R6, R8 and R10 have unnecessary large routing tables as they are stub areas (well I'm not sure if you can call R5 a stub area as it is RIP), what can I do to reduce the routing tables on these?
Rather than post all the configs and routing tables, let me know what I can post to help.  I wanted to make R10 a stub area but as it is a virtual link I cant, for example it's routing table is:
Gateway of last resort is not set
     1.0.0.0/32 is subnetted, 1 subnets
O E2    1.1.1.1 [110/20] via 9.1.1.9, 00:29:28, FastEthernet0/0
     2.0.0.0/32 is subnetted, 1 subnets
O E2    2.2.2.2 [110/20] via 9.1.1.9, 00:29:28, FastEthernet0/0
     20.0.0.0/32 is subnetted, 1 subnets
O E2    20.2.2.2 [110/20] via 9.1.1.9, 00:29:28, FastEthernet0/0
     5.0.0.0/32 is subnetted, 1 subnets
O E2    5.5.5.5 [110/20] via 9.1.1.9, 00:29:28, FastEthernet0/0
     6.0.0.0/32 is subnetted, 1 subnets
O E2    6.6.6.6 [110/20] via 9.1.1.9, 00:29:30, FastEthernet0/0
     37.0.0.0/30 is subnetted, 1 subnets
O       37.1.1.0 [110/138] via 9.1.1.9, 00:29:30, FastEthernet0/0
     7.0.0.0/24 is subnetted, 1 subnets
O       7.7.7.0 [110/75] via 9.1.1.9, 00:29:30, FastEthernet0/0
     8.0.0.0/32 is subnetted, 1 subnets
O E2    8.8.8.8 [110/20] via 9.1.1.9, 00:29:30, FastEthernet0/0
     9.0.0.0/24 is subnetted, 1 subnets
C       9.1.1.0 is directly connected, FastEthernet0/0
     78.0.0.0/24 is subnetted, 1 subnets
O       78.1.1.0 [110/84] via 9.1.1.9, 00:29:30, FastEthernet0/0
     26.0.0.0/30 is subnetted, 1 subnets
O E2    26.1.1.0 [110/20] via 9.1.1.9, 00:29:30, FastEthernet0/0
     79.0.0.0/24 is subnetted, 1 subnets
O       79.1.1.0 [110/74] via 9.1.1.9, 00:29:30, FastEthernet0/0
O E2 192.168.1.0/24 [110/20] via 9.1.1.9, 00:29:30, FastEthernet0/0
     15.0.0.0/30 is subnetted, 1 subnets
O E2    15.1.1.0 [110/20] via 9.1.1.9, 00:29:30, FastEthernet0/0
R10#
154
