help understanding route-targets
John Blakley
All,
I've set up an mpls network in gns, and I had a question about route-targets. I'm assuming that a route-target is nothing more than an arbitrary number that matches other route-targets. If it doesn't match, then the routes don't get injected into the vrf table.
If that's the case, are the import and export commands used to be able to say if that particular router will import a route from a matching RT, and export a route from a matching RT, and if I said I only wanted to import a route from a matching RT, would that keep me from advertising a route from the vrf table if I haven't specified to export? (Long winded, I know.) :)
John
HTH, John *** Please rate all useful posts ***
2 Accepted Solutions
John,
You are absolutely right in your assumption. The Blue VRF exports all its locally-injected networks with a set of two RTs: 100:100 and 100:200. The Black VRF imports all routes that have their RT equal to either 100:100 or 100:200 (or even both but it suffices to match at least one). Therefore, the Black VRF will know about all routes in the Blue VRF.
And also it won't work the other way round. The Black VRF exports all its locally-injected networks with a single RT set to 100:200. The Blue VRF imports networks only with the RT equal to 100:100, so no match will be found here and the Blue VRF will know nothing about Black VRF's networks.
Best regards,
Peter
Peter and John,
In the above scenario under vrf blue you do not need route-target export 100:200
you only need the import under vrf black.
Here is the config:
ip vrf black
rd 100:200
route-target import 100:200
route-target import 100:100
ip vrf blue
rd 100:100
route-target export 100:100
T-1#sh run int lo100
Building configuration...
Current configuration : 97 bytes
interface Loopback100
ip vrf forwarding blue
ip address 100.100.100.100 255.255.255.255
end
T-1#sh run int lo200
Current configuration : 98 bytes
interface Loopback200
ip vrf forwarding black
ip address 200.200.200.200 255.255.255.255
end
T-1#sh ip rou vrf black
Routing Table: black
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
200.200.200.0/32 is subnetted, 1 subnets
C 200.200.200.200 is directly connected, Loopback200
100.0.0.0/32 is subnetted, 1 subnets
B 100.100.100.100 is directly connected, 00:19:16, Loopback100
T-1#sh ip rou vrf blue
Routing Table: blue
C 100.100.100.100 is directly connected, Loopback100
T-1#
vrf black has both 100.100.100.100 and 200.200.200.200
But vrf blue has only 100.100.100.100
Reza
9 Replies 9
Peter Paluch
John,
The Route Target (RT in short) is basically a BGP attribute that can be assigned to networks in a particular VRF. Multiple RTs can be assigned to a single route when advertising it to a peer, and they can of course be compared to a set of allowed RTs when importing it into a VRF.
The RTs are usually set using the "route-target" command in the VRF configuration. This command has two uses:
1.) As route-target export, it defines what RTs will be set on networks exported from that particular VRF to your BGP peers. In other words, it defines into which VRFs can these networks be imported.
2.) As route-target import, it defines what RTs (at least one) must a network have in order to be imported into that particular VRF. In other words, it defines which networks (according to their RT) will be imported, provided that it was allowed by the "route-target export" in the previous step.
The "route-target export" does not work as a filter. It is only a statement that says what RT or a set of RTs should a locally originated route have when advertising it to BGP peers. However, this command does not do any filter of the advertised networks, and also, if the networks already have RTs set, it will not change it.
I don't know if this fully answers your question. Please ask further.
Best regards,
Peter
Peter,
That's a great explanation.
Can you share routes between customers by importing their route target information?
ip vrf Blue
rd 100:100
route-target both 100:100
ip vrf Black
rd 100:200
route-target both 100:200
Would the above work? I don't have gns to play with now, but I'd like to test this. I'm assuming, and that's a BIG assumption, that the above would allow Black to see Blue's routes. Is this not the case? (It may even be totally invalid.)
Thanks!
John
John,
Best regards,
Peter
Awesome! That's the understanding I needed! Thanks Peter!
John
Peter and John,
Here is the config:
ip vrf black
rd 100:200
ip vrf blue
rd 100:100
end
end
Routing Table: blue
T-1#
Reza
Reza,
Thank you for your insight. Of course, you are right. I just took John's example and explained what would happen if he configured it the way he suggested. However, you are completely correct, in this case there is no need to set two export RTs on the Blue VRF.
Thank you for updating this topic.
Best regards,
Peter
Thanks Reza! I appreciate it!
John
Peter,
I noticed that even though I see the route from the blue vrf in black, but I can't ping the loopback address of the blue (100.100.100.100).
Now, of course if I use the import command for both vrfs, they can see each others route and also can ping either loopback interfaces
I wonder, if I need to add vrf select/receive command to the blue loopback interface to get it to work.
Reza
Hello Reza,
I think you have pretty much explained it yourself. You may be pinging the Blue loopback but the Blue VRF does not have the route back to the Black VRF. They need to see each other.
Best regards,
Peter
