Help - Want to pass data from 1 ATM port to another, same Router
bhimebauch
I am trying to send data from GigE1 to ATM1/0 to ATM2/0 to GigE2. My real intent is to send Multicast data, but have since backed out the Mulitcast commands, just focusing on getting ICMP pings to pass. My configuration is as follows:
Current configuration : 1776 bytes
version 12.3
no service pad
hostname NGN_ROUTER
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no crypto isakmp ccm
interface GigabitEthernet0/1
ip address 70.10.0.1 255.0.0.0
ip policy route-map GigE-2-ATM-Forced-Video
duplex auto
speed auto
media-type rj45
no negotiation auto
interface GigabitEthernet0/2
no ip address
ip pim sparse-dense-mode
duplex auto
speed auto
media-type rj45
no negotiation auto
interface GigabitEthernet0/3
ip address 80.10.0.1 255.0.0.0
duplex auto
speed auto
media-type rj45
no negotiation auto
interface ATM1/0
ip address 100.10.0.1 255.0.0.0
no ip redirects
no ip proxy-arp
ip policy route-map ATM-2-ATM-Forced-Video
atm clock INTERNAL
atm sonet stm-1
no atm ilmi-keepalive
pvc 1/32
protocol ip 100.10.0.1
encapsulation aal5snap
interface ATM2/0
ip address 90.10.0.1 255.0.0.0
no ip redirects
no ip proxy-arp
ip policy route-map ATM-2-GigE-Forced-Video
atm clock INTERNAL
atm sonet stm-1
pvc 1/32
protocol ip 90.10.0.1
ip classless
no ip http server
no ip http secure-server
route-map GigE-2-ATM-Forced-Video permit 10
match interface GigabitEthernet0/1
set ip next-hop 100.10.0.1
route-map ATM-2-GigE-Forced-Video permit 10
match interface ATM2/0.1
set ip next-hop 80.10.0.1
route-map ATM-2-ATM-Forced-Video permit 10
match interface ATM1/0.1
set ip next-hop 90.10.0.1
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
I'm trying ot force the data from the GigE1 to ATM1/0, then force from ATM1/0 to ATM2/0, then ATM2/0 to GigE2. With this configuration, I am not seeing any data using the show atm traffic.
Can anybody help?
Bruce
bhimebauch
Sorry, all references to GigE2 is actually GigE3
There are some obvious errors in your config.
Firstly, under the ATM interfaces, you have to use the 'protocol ip' command to specify addresses of other devices reachable through the interface, not the local IP address.
Secondly, the 'match interface' command is not required in your route-maps - it will match on packets that are routed out of the specified interface which is not what you want.
Thirdly, in your route-maps, use the 'set ip next-hop' command to specify the IP of a router reachable through the interface, not a local interface IP.
Hope that helps - pls rate the post if it does.
Paresh
Thanks, will try in the morning.
