help with ACLs and GRE Tunnel
usuario0001
I have a site-to-site VPN with a GRE Tunnel between two sites and two Cisco 2811.
There are 2 groups of PCs from local site, one of them must connect to several servers from remote site
via Internet connection and the other group of PCs via Gre Tunnel, is it possible? Is it possible that
a server can connect via Internet to some PCs and via Gre Tunnel to other PCs?
Servers from remote site have public IP adressess.
These are the current configurations and I have to change them in order to get what I have explained:
Remote router:
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key 123456 address xxx.xxx.xxx.xxx
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map IPSEC_VPN 1 ipsec-isakmp
set peer xxx.xxx.xxx.xxx
set transform-set ESP-3DES-SHA
match address 101
interface Tunnel1
ip address 10.1.1.1 255.255.255.252
ip access-group 10 out
ip nat inside
ip virtual-reassembly
keepalive 10 3
tunnel source Vlan1
tunnel destination xxx.xxx.xxx.xxx
interface Vlan1
ip address aaa.aaa.aaa.1 255.255.252.0
ip nat outside
ip route 0.0.0.0 0.0.0.0 aaa.aaa.aaa.aaa
ip route 192.168.3.0 255.255.255.0 10.1.1.2
ip nat inside source static 192.168.3.2 aaa.aaa.aaa.2
access-list 10 permit aaa.aaa.aaa.2
access-list 10 permit aaa.aaa.aaa.3
access-list 10 permit aaa.aaa.aaa.4
access-list 10 permit aaa.aaa.aaa.5
access-list 10 permit aaa.aaa.aaa.6
access-list 101 permit gre host aaa.aaa.aaa.1 host xxx.xxx.xxx.xxx
Local router:
encr 3des
group 2
crypto isakmp key 123456 address aaa.aaa.aaa.1
set peer aaa.aaa.aaa.1
match address 101
interface Tunnel1
ip address 10.1.1.2 255.255.255.252
ip access-group 16 out
keepalive 10 3
tunnel source FastEthernet0/0
tunnel destination aaa.aaa.aaa.1
interface FastEthernet0/0
description Connection to VLAN 302
ip address xxx.xxx.xxx.xxx 255.255.255.252
ip nat outside
load-interval 30
duplex auto
speed auto
interface FastEthernet0/1
description Local LAN
ip address 192.168.3.1 255.255.255.0
ip nat inside
load-interval 30
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 ddd.ddd.ddd.ddd
ip route aaa.aaa.aaa.0 255.255.252.0 10.1.1.1
ip http server
no ip http secure-server
ip nat inside source list 5 interface FastEthernet0/0 overload
access-list 5 permit 192.168.3.2
access-list 5 permit 192.168.3.3
access-list 5 permit 192.168.3.4
access-list 5 permit 192.168.3.5
access-list 5 permit 192.168.3.6
access-list 5 permit 192.168.3.7
access-list 16 deny 192.168.3.4
access-list 16 deny 192.168.3.5
access-list 16 deny 192.168.3.6
access-list 16 deny 192.168.3.7
access-list 16 permit any
access-list 101 permit gre host xxx.xxx.xxx.xxx host aaa.aaa.aaa.1
Thanks in advance
3 Accepted Solutions
ktwaddell
Have you considered using policy base routing here, that way you can use the ACL's and point each ACL for 2 different routes!
Kev
Peter Paluch
I am not going to suggest a particular configuration example right now but only an overview of how it could be done.
I assume that the PCs use a single gateway, and also, that the servers use a single gateway. If it is so then it is the routing table that decides where to forward each packet. One possible solution would be to enter host routes (entries about individual IP addresses with /32 mask) into the routing table so that some entries point to the internet while others point to the tunnel. If the groups of PCs are summarizable using a single subnet then it would be even more efficient, as it would require less entries in the routing table.
Another way to do this would be by using Policy Based Routing.
Best regards,
Peter
Yes, you are right, the command is on the remote site while the network 192.168.3.0/24 is on the local site.
I do not know for sure what was the intention of the person that configured this, but presently, it works as follows:
On the local router, you can see that there is a static routing entry saying "ip route aaa.aaa.aaa.0 255.255.252.0 10.1.1.1". So, when also your local network wants to reach aaa.aaa.aaa.0/22 it will get forwarded to the other site. Now imagine that the machine 192.168.3.2 in your local network wanted to talk to workstation aaa.aaa.aaa.x/22 on the remote site. The packet will be tunelled to the remote router and now, because the Tunnel interface is configured as NAT inside and Vlan1 as NAT outside, this particular workstation will be NATted as aaa.aaa.aaa.2.
In other words, if the 192.168.3.2 communicates with the network aaa.aaa.aaa.0/22, it will be translated to aaa.aaa.aaa.2. For machines on the remote location, it will appear as a node in their own network.
For other traffic directions, this NAT does not apply.
Best regards,
Peter
9 Replies 9
ktwaddell
Kev
Kev,
If the only key to decide about the packet's route is the destination address then I think that using PBR is somewhat of an overshoot. It would certainly work but you can achieve the same thing simply by entering proper entries into a routing table (which is CEF-switched - the PBR is probably not).
Best regards,
Peter
EDIT: I stand corrected about the CEF. Since IOS 12.0, the PBR is supported in the CEF switching path.
Peter,
If the packet route is the single key factor then yes PBR is a bit over the top, the simply design is normally the best.
Cheers
Kev
Peter Paluch
Best regards,
Peter
Ok, I will try to add entries in the routing table.
Just a last question, what are this two
commands? I know the second one is to permit IP address aaa.aaa.aaa.1 to access the GRE Tunnel, but what about the first one?
ip nat inside source static 192.168.3.2 aaa.aaa.aaa.1
access-list 10 permit aaa.aaa.aaa.1
Thanks and regards
The first command creates a static NAT translation entry for inside address 192.168.3.2 and maps it to aaa.aaa.aaa.1. So, if that station talks to outside world, it appears as aaa.aaa.aaa.1, and vice versa, if the outside world sends a packet to aaa.aaa.aaa.1, it will be translated and sent to 192.168.3.2.
Best regards,
Peter
But, this command is in the remote router and the PC with this address 192.168.3.2 is in local site, so if this PC talks to outside world doesn't goes through remote router to translate its direcction, just goes through the local router, doesn't it?
thanks
Best regards,
Peter
Now I understand it.
Thank you for your help.
Best regards.
