Community Member
help with adsl/wirless config
please help.
I am trhing to configure the wireless on my cisco 877w router. the wired lan side of it is working perfectly I just need to get the wireless working. currenty the users can not see the ssid.
how does my config look?
thanks a mill
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: help with adsl/wirless config
From console connection, configure as follows:
no ip dhcp excluded-address 10.10.20.1 10.10.20.10
no ip dhcp pool wireless-pool
no interface Dot11Radio0.1
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface vlan 1
no ip address
no ip nat inside
no ip virtual-reassembly
interface bvi1
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
no interface dialer 0
interface dialer 1
no ip tcp adjust-mss 1452
no dialer-group 1
ppp ipcp default route
ip access-list extended 101
no 20
no dialer-list 1
no ip route 0.0.0.0 0.0.0.0 Dialer1
interface range fa0 - 3
switchport portfast
Please specify if you want the wireless PCs on a different subnet as your config seems to indicate, or you're fine with them being in the same subnet as the wired PCs.
Community Member
I dont want them to get a different IP. I want them to get an address from the dhcp pool lan-pool if possible.
thanks
bridge-group 1
interface vlan 1
no ip address
no ip nat inside
interface bvi1
ip nat inside
interface dialer 1
no dialer-group 1
no 20
no dialer-list 1
switchport portfast
Community Member
if I apply this config it will break my wired clients?
here is the current config. the users can now associate but can not get an IP?
Nothing will break. Please apply *in full* the configuration per my previous, from a console connection.
In addition to that, also configure:
no ip dhcp-server 10.10.10.1
Community Member
I dont have console access I am telnet on and also have http access
Then you have to apply configuration changes with an editor to your configuration file.
for the "no" commands, just remove the whole line.
After that copy said file in the router as startup-config via tftp, http, or ftp server, once you verify the correct file is in there, reload router.
Community Member
is there no other way of getting this working?
No, the problem is that you may active nat translations preventing you from changing the addresses as required.
You can try "clear ip nat" commands, but the sure way is the one I've described before.
Community Member
there is not nat translations.
from your config how will wired clients get an ip address and how will the router nat for those?
Then you can apply the config changes straight from telnet.
Both vlan1 and radio interface are bridged under BVI1 and get addresses per dhcp pool that matches router address for said interface
Community Member
i dont have the option
under int dialer 1 interface config?
and how will the router know how to route to default gateway by doing
and with a no dialer list command what will allow IP out?
Leave the defaulr route change out. It is not essential and your IOS may be too old to support that.
No dialer list is needed for PPPoE connections. The connection is open all the time.
Community Member
this is the current config now so you think this should work now for wireless and wired clients?
439
