Community Member
Help with AIM-ATM and VWIC install
I have just installed an AIM-ATM card and a VWIC-1MFT-G703 card in a 3745.
After restarting the router, it would appear that the WIC card is not being recognised.
There is also no "controller" command available from global config.
Output of show ver and show diag below, any help appreciated
Lee
IOS (tm) 3700 Software (C3745-IS-M), Version 12.3(3e), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 21-Jan-04 14:40 by pwade
Image text-base: 0x60008954, data-base: 0x61B40000
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
LONRTR04 uptime is 2 hours, 34 minutes
System restarted at 19:11:59 BST Thu Jun 21 2007
System image file is "flash:c3745-is-mz.123-3e.bin"
cisco 3745 (R7000) processor (revision 2.0) with 116736K/14336K bytes of memory.
Processor board ID JHY0809K11L
R7000 CPU at 350Mhz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
3 FastEthernet/IEEE 802.3 interface(s)
1 ATM AIM(s)
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of non-volatile configuration memory.
31168K bytes of ATA System CompactFlash (Read/Write)
WIC Slot 0:
Unknown WAN daughter card
Hardware revision 2.0 Board revision 90
Serial number 67110400 Part number 08-0010-00
Test history 0xC RMA number 00-14-00
Connector type PCI
EEPROM format version 0
EEPROM contents (hex):
0x20: 00 00 02 00 04 00 06 00 08 00 0A 00 0C 00 0E 00
0x30: 10 00 12 00 14 00 16 00 18 00 1A 00 0C 00 1E 00
ATM AIM: 0
ATM AIM
Hardware Revision : 1.0
Top Assy. Part Number : 800-06558-06
Board Revision : B0
Deviation Number : 0
Fab Version : 07
PCB Serial Number : FOC11162FY1
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : AIM-ATM
Unknown Field (type 0089): 56 30 31 20
CLEI Code : CNUIALRAAA
EEPROM format version 4
0x00: 04 FF 40 01 B0 41 01 00 C0 46 03 20 00 19 9E 06
0x10: 42 42 30 88 00 00 00 00 02 07 C1 8B 46 4F 43 31
0x20: 31 31 36 32 46 59 31 03 00 81 00 00 00 00 04 00
0x30: CB 87 41 49 4D 2D 41 54 4D 89 56 30 31 20 C6 8A
0x40: 43 4E 55 49 41 4C 52 41 41 41 FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Community Member
Re: Help with AIM-ATM and VWIC install
Looks like I might have found the answer
VWIC2-1MFT requires 12.3(14)T minimum. Can anyone confirm this please.
Lee
Confirmed, but only if you are using the NM-HDV2, please refer to the Software Advisor:
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800b6e0f.shtml
HTH,
Mohammed Mahmoud.
Hall of Fame Super Gold
The way I understand it, requirement is 12.3(14)T not matter if sits in a WIC slot or on an NM...
Hi Paolo,
From the link above, the IOS constrain is only when using NM-HDV2, and its not supported at all on the NM-HDV and NM-HD-2VE.
BR,
Mohammed Mahmoud.
Mohammed, I assume is VWIC2 like mentioned in the second post and not a VWIC as per initial post. Lee is trying to use the card for a data T1 ATM link, not voice. He must insert the card in a WIC slot and the card is supported from 12.3(14)T onward:
http://cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a008042052c.html
Hi Paolo,
I thought it is a VWIC-1MFT-G703 as per his initial post and that he has done a typo error in the second post, and i think that you are right he is trying to use the card for data not voice, i was just trying to give him a generalized answer then elaborating to his specific solution, may be now the original poster can verify as he has all the input he needs.
BR,
Mohammed Mahmoud.
Community Member
I think you will find that you need to install a different IOS feature set than the one currently in the 3745 router. The IOS that you currently have is "IP Plus." If you ordered the ATM Bundle, you received a CD-ROM with the "SP Services" feature set. If you didn't order an ATM Bundle, you will have to download the SP Services feature set from Cisco's Web site. Once you have upgraded to the SP Services feature set, you will neeed to issue a "voice-card 0" configuration command, at which point you should be able to see and configure your E1 controllers.
531
