08-13-2012 01:13 AM - edited 03-04-2019 05:15 PM
I set up a basic Linksys E2500 with the following information and connected to the internet straight away without a problem:
I have spent several hours simply trying to get this basic information into the Cisco 819 using CP Express without success, i.e. I get no internet. Rather than show my inputs, I'd appreciate some guidance of the correct setup. I am a novice so I'd rather solve this issue using CP Express just to get connected in the first instance.
By the way, I have a static IP address, I connected the ethernet cable carrying the internet to the internet port of the E2500 and an ethernet cable from one of the ethernet ports of the E2500 to my PC. For the 819, I connected the internet cable to the GE WAN 0 port and the PC to one of the FE ports. Thanks.
Solved! Go to Solution.
08-14-2012 08:02 AM
just mark the thread as resolved and rate any post you found valuable.
PM me and we'll find a way to test it and see what is not working.
Regards.
Alain.
08-13-2012 04:55 AM
CP Express and other GUI often don't work, use CLI for sure results.
08-13-2012 05:47 AM
OK, I have connected to the router using Putty over the serial port. I have managed to configure the basic stuff like router name and change username/pwd etc... However, the user guide is not too helpful regarding configuring the GE WAN and other FE ports. Can you help there please? Thanks.
08-13-2012 05:52 AM
Are you connected via WAN interface to a xDSL modem or modem/router ?
Regards.
Alain.
08-13-2012 06:24 AM
Hi Alain, I don't know the exact modem or whether it is a modem/router or just modem but the network is SDSL. Does it matter? Thanks,Joel
08-13-2012 06:57 AM
if the Linksys router was already connected to this device with the config you posted then this is a modem only and so the config should look like this:
interface vlan 1
ip nat inside
exit
no ip dhcp conflict-logging
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp excluded-address 192.168.1.150 192.168.1.254
ip dhcp pool mypool
network 192.168.1.0 /24
default-router 192.168.1.1
dns-server 195.129.12.x 135.196.0.x
exit
interface g0/0
ip address 88.211.8.x 255.255.255.x ----> your WAN static IP
ip nat outside
access-list 99 permit 192.168.1.0 0.0.0.255
ip nat inside source list 99 interface g0/0
ip route 0.0.0.0 0.0.0.0 88.211.8.x ----> your default-gateway
Try to ping 8.8.8.8 from a host attached to one of the LAN interfaces and if it works then you got done.
Regards.
Alain
08-13-2012 07:04 AM
Ah, I see. Sorry, for the confusion then. The E2500 was just there to test the line and my connection credentials. It is no longer in the network. I just want to configure the 819 to work directly from the SDSL cable into its GE WAN 0 port.
08-13-2012 07:45 AM
try what I posted and let us know.
Regards.
Alain
08-13-2012 08:23 AM
Hi Alain, I really appreciate your help and patience on this. Unfortunately, it did not work. Now, the PC does not even receive an IP address from the router, let alone connect to the internet! My building IT manager said the router may not work if it has a built-in modem. Could this really be an issue?
08-13-2012 12:44 PM
could you post following outputs:
- sh ip int br | i Vlan
-sh ip route
-sh int status
Have you connected the host with a straight cable and have you tried releasing/renewing the DHCP address on the host ?
Regards.
Alain
08-13-2012 11:51 PM
concerning the xdsl stuff then we should do PPPoE on the router:
so here is the part to change
interface G0/0
no ip address
pppoe enable
pppoe-client dial-pool-number 1
no shut
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp authentication chap callin
ppp chap hostname xxx ---> your login
ppp chap password xxx ---> your password
no shut
ip nat inside source list 99 interface dialer1
no ip route 0.0.0.0 0.0.0.0 88.211.8.x
ip route 0.0.0.0 0.0.0.0 dialer1 ----> your default-gateway
Regards.
Alain
08-14-2012 01:27 AM
Morning Alain,
Yes, the router is connected to the host with a striaght through cable (the one supplied by Cisco). I have tried several times to renew the lease and even manually set the host onto the same subnet as the router and cannot access the router by typing its IP address into a browser. Here is what I have done so far. I had to change some of your script to match my interface names etc (my changes in bold) but there is still one command that is not recognised by the CLI - "access-list":
configure
terminal
interface Vlan1
ip nat inside
exit
no ip dhcp conflict logging
ip dhcp pool mypool
dns-server 195.129.12.114 135.196.0.6
exit
interface GigabitEthernet0
ip address 88.211.8.xxx 255.255.255.252
ip nat outside
access-list 99 permit 192.168.1.0 0.0.0.255 <=== this line not accepted
ip nat inside source list 99 interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 88.211.8.xxw
exit
Is the config saved automatically at this point or do I have to force a save somehow? Here are the results of the check commands:
- sh ip int br | i Vlan1
Vlan1 192.168.1.1 YES manual administratively down down
-sh ip route
Default gateway is not set
Host Gateway Last Use Total Uses Interface
ICMP redirect cache is empty
-sh int status
Port Name Status Vlan Duplex Speed Type
Fa0 connected 1 a-full a-100 10/100BaseTX
Fa1 disabled 1 auto auto 10/100BaseTX
Fa2 disabled 1 auto auto 10/100BaseTX
Fa3 disabled 1 auto auto 10/100BaseTX
When I check the host, the IPv4 autoconfig is 169.254.240.17.
I do not have a username and password and I don't need one to connect (as evidenced by the success in connecting the E2500). I don't think there is PPPoE. The building IT manager said I should be able to connect just with the supplied IP address, subnet mask, def gway and DNS servers. Indeed I can with the E2500. Should the 819 really be this difficult? Do you think it is faulty?
Thanks as always for your help!
08-14-2012 02:01 AM
do this:
- interface vlan 1
no shut
- enable ip routing as it may have been disabled (from the sh ip route output) with the global configuration command: ip routing and do a no shut on the G0/0 interface also.
Then you should get a dhcp address on the host.
-concerning the access-list try to configure it in global config mode so exit out from interface before configuring it
Yes you must save the config with either the wr command or the copy run start command done in privileged mode( # prompt) or in config mode by prefixing with the do keyword.
When you got DHCP going correctly then try to ping 8.8.8.8 from the router and let us know
Regards.
Alain
08-14-2012 02:35 AM
Alain, seriously, you rock! Ping success and I can finally connect to the internet. For completeness and to help other users, I am pasting the final full config I used here:
configure
terminal
interface Vlan1
no shut
ip nat inside
exit
ip dhcp pool mypool
exit
ip address 88.211.8.xxx 255.255.255.252 ////Static IP address
ip nat outside
exit
ip route 0.0.0.0 0.0.0.0 88.211.8.xxw ////Default Gateway
exit
ip routing
exit
copy running-config startup-config
CTRL/Z
So now I should be safe to turn the router off and on again and still be configured?
Here are the results of the tests:
- sh ip int br
Cellular0 unassigned YES unset down down
FastEthernet0 unassigned YES unset up up
FastEthernet1 unassigned YES unset administratively down down
FastEthernet2 unassigned YES unset administratively down down
FastEthernet3 unassigned YES unset administratively down down
GigabitEthernet0 88.211.8.138 YES manual up up
NVI0 unassigned NO unset up up
Serial0 unassigned YES unset administratively down down
Vlan1 192.168.1.1 YES manual up up
-sh ip route
Gateway of last resort is 88.211.8.xxw to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 88.211.8.xxw
88.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 88.211.8.xxv/30 is directly connected, GigabitEthernet0
L 88.211.8.xxx/32 is directly connected, GigabitEthernet0
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, Vlan1
L 192.168.1.1/32 is directly connected, Vlan1
-sh int status
If I may use you for just a few more things?
Can you help me with these too?
Cheers, Joel
08-14-2012 04:09 AM
I'm happy you made it work
Now you can reload the router and the config will still be there and working.
for the other things:
1) just connect a host with the correct cable into the port and it will get an IP address from DHCP
2) for port forwarding: x.x.x.x is the IP address of the internal host listening on the port
VNC ---> ip nat inside source static tcp x.x.x.x 5900 interface g0/0 5900
ip nat inside source static tcp x.x.x.x 5800 interface g0/0 5800
SQL ---> ip nat inside source static tcp x.x.x.x 1433 interface g0/0 1433
For the security there are lots of things you can do like:
- disable telnet access and configure ssh instead and use an ACL for restricting the hosts that can ssh into the device:
http://www.cisco.com/en/US/tech/tk583/tk617/technologies_tech_note09186a00800949e2.shtml
- disable cdp on the external interface : no cdp enable on g0/0 interface
- use IOS login enhancements: http://www.cisco.com/en/US/docs/ios/12_3t/12_3t4/feature/guide/gt_login.html
- configure ZBF( Zone based Firewall): http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00808bc994.shtml
3)for secure wifi:http://www.cisco.com/en/US/docs/routers/access/800/850/software/configuration/guide/wireless.html
http://www.cisco.com/en/US/docs/routers/access/1800/wireless/configuration/guide/awg.html
If you need any help on one of these tasks just open a new thread and we'll do our best to help you.
Regards.
Alain.
