Help with BGP convergance.....
We have a WAN on MPLS that is using
BGP. We are getting 25 to 35 second convergance but we need to do better. I have the router config's and a drawing of the
network if someone thinks they could help us improve this. Thanks in advance.......
  • WAN Routing and Switching
Re: Help with BGP convergance.....
Is it eBGP or iBGP that you're using? You can change timers per neighbor to help with convergence. Something like:
neighbor x.x.x.x timers 5 15
BGP will select the lower timer of the 2 peers (meaning if your peer is 60 180 (default), it will scale down to match yours.)
There is a recommendation for not going lower than 20 seconds because it can increase the chance of bgp flapping.
HTH,
John
HTH, John *** Please rate all useful posts ***
We have adjusted the timers but we still see the 25 to
35 seconds to converge.....I wonder if we are missing something in the config????
Can you post the config?
Here's the configs from the routers ..... I'll post a drawing next
Thanks again for your help
James
Here's the drawing
Let me know if you have any questions about this.....
Gonna take me a little time to look at this. Where are these routers in your diagram? I don't see the AS listed that you have in the configs.
John
There are a couple of things that you can try that I don't see in your config. There's an option in BGP called fall-over. It helps speed up convergence on the
detection of a loss of the peer. I would apply it to the iBGP peers and see if that helps with your convergence. You can also try to enable graceful-restart to see if that helps as well.
HTH,
John
We looked at fall over but it said it needed host routes and not loopbacks....it didn't seem to fit with our design....please take all the time you need.....I get off work between 5 and 5:30 EST....I'll most likely be back on tonight from home.....this amusment never ends.....
John,
     I went back in and looked at the timers again.....I reset them and it inproved the convergance greatly....we now see 6-7 seconds until the network convereges....I'm not sure we could do better than that....so today more testing ....thanks for your help...
James
481
