Help with DNS on WAN/LAN interfaces
OliverDarvall
Guys,
I have a 2800 with one Gigabit interface connection to our Lan and the other interface connected to the internet with a public IP address. Now I'd like to setup the router to resolve both internal and external DNS requests. Thus requests like www.google.co.za and LocalLanPcName should be resolved to their public and private IP's respectively.
show ip dns view default :
DNS View default parameters:
Logging is off
DNS Resolver settings:
  Domain lookup is enabled
  Default domain name: secmansol.local
  Domain search list:
  Lookup timeout: 3 seconds
  Lookup retries: 2
  Domain name-servers:
    192.168.1.200
    192.168.1.201
DNS Server settings:
  Forwarding of queries is enabled
  Forwarder timeout: 3 seconds
  Forwarder retries: 2
  Forwarder addresses:
    41.160.0.36
    41.160.0.37
When I ping any name the only DNS server that is ever queried is 192.168.1.200 (it does resolve internal name correctly though).
None of the other servers are attempted to resolve the name. It does not matter if I specify a FQDN or not.
How do I setup the router so that my internal resolution is handled by 192.168.1.200 and .201, while external resolution is handled by 41.160.36 and .37. Or alternatively, how do I configure it to at least try all 4 specified name-servers for resolution, and not fail after trying the first one unsuccessfully.
Thanks !
9 Replies 9
Hi Oliver,
ip domain-lookup
ip name-server
Smitesh
PS: Please rate if helpful...
Smitesh,
Thanks for the reply. Herewith all the DNS related settings in my config (in the order that they appear in the config):
ip domain name secmansol.local
ip name-server 192.168.1.200
ip name-server 192.168.1.201
ip dns view default
dns forwarder 41.160.0.36
dns forwarder 41.160.0.37
ip dns server
I have entered the ip domain-lookup command (numerous times), but it does not appear in the config as I assume it is on by default.
Yet still with the above whenever a name is resolved only the 192.168.1.200 server is used, even if the resolution fails. The other 3 servers are never used.
Any ideas ?
Thanks !
Oliver,
Since you have given the command ip domain name secmansol.local; it will try to append that to make it FQDN.
Can you try the following,
remove  the following configs:
ip dns view default
ip dns server
and add the following config:
ip name-server 8.8.8.8
Smitesh
Smitesh,
I tried your suggestion, herewith my new config entries :
     ip name-server 41.160.0.36
and then I tried to ping a local/vpn :
     #ping vpnsiteserver
     Translating "vpnsiteserver"...domain server (8.8.8.8)
     % Unrecognized host or address, or protocol not running.
and then tried to ping a internet site :
     #ping www.microsoft.com
     Translating "www.microsoft.com"...domain server (8.8.8.8) [OK]
     Sending 5, 100-byte ICMP Echos to 64.4.11.17, timeout is 2 seconds:
I am out of ideas here ...
Take a look at this:
ip host www.example.com 192.168.01
ip host mail.example.com 192.168.0.2
ip dns view default
domain name example.com
domain name-server  8.8.8.8
domain name-server  8.8.4.4
dns forwarder 8.8.8.8
dns forwarder 8.8.4.4
ip dns view-list DNS_VIEW_LIST
view default 10
ip dns server
ip dns primary example.com soa ns.example.com webmaster.example.com 21600 900 7776000 86400
The router will try to resolve anything for domain example.com [in this www and mail.example.com] and if it can not resolve it it will forward to 8.8.8.8 and 8.8.4.4
It should work !
Jose,
Herewith the relevant new DNS settings from my config :
ip host bugrogers.secmansol.local 192.168.1.200
ip host bidibidi.secmansol.local 192.168.1.201
ip dns view default
domain name-server  192.168.1.200
domain name-server  192.168.1.201
domain name-server  41.160.0.36
domain name-server  41.160.0.37
dns forwarder 192.168.1.201
dns forwarder 192.168.1.200
view default 10
ip dns server
ip dns primary secmansol.local soa 192.168.1.81 webmaster.secmansol.local 21600 900 777600 86400
But alas, my ping results are still the same !
Router#ping www.google.co.za
Translating "www.google.co.za"...domain server (192.168.1.200)
Router#
I have now also update my IOS just in case, but the same results ...
Do you have forwarders configuered on 192.168.1.200/1? On your initial request you said "Now I'd like to setup the router to resolve both internal and external DNS requests." but now you're asking another internal host [192.168.1.200/1] to resolve names. The 41.160.x.x servers won't do you much good in this case; they would only work if .200 and .201 did not answer.
Try taking the .200 and .201 domain name-server and dns forwarder lines off the default dns view and try again (after clearing dns cache of course)... if this is what you want.
My terminology sucked in my initial post, sorry guys. I do not particularly want my router to resolve the DNS requests, I just want it to pass/handle the request on to the relevant DNS servers for resolving.
Thus internal request for resolution of names like server1 (.secmansol.local) and server2 (.secmansol.local) I want to have handled by 192.168.1.200 and .201.
While requests for internet DNS's like www.google.com to be handled by our ISP's DNS servers 40.160.0.36 and .37.
Is this possible ?
Jose: I assume from your description that having multple DNS's servers only really comes into play when a DNS server does not reply on a request, then only is it passed on to the next server. So if a server receives a resolution request for a name and it replies that it can not resolve it, then the request is not passed on to the next server specified ?
Of couse it's possible. Have you configured forwarders on 192.168.1.200 and .201 to 40.160.0.36 and .37? (I would guess not)
Another option... have you considered not running DNS on the router?
- no ip dns server
- on 192.168.1.200 and .201 configure forwarders to 40.160.0.36 and .37
- on client's DNS configuration place 192.168.1.200 and .201
Give it a shot !
