Help with DSL failover on 1841
I have a remote Cisco 1841 which is currently configured to create a Easy VPN tunnel across a T-1 to a 3005 concentrator in corporate office. I would like to attach a DSL circuit to router's 2nd FE port to use as failover if T-1 goes down. What is the easiest way to do this?
Re: Help with DSL failover on 1841
assuming that you want the 2nd FE port to be configured as a VPN tunnel, too, what you could do is create a second crypto map, and then use the 'backup interface FastEthernet2' command on the T1 interface to configure the backup.
Does that make sense ? Do you need specific help with the configuration details ? If so, post your current configuration, if possible.
GNT
Yes, any pointers on configuration commands would be very much appreciated. Here is the current configuration:
hostname rtr-field
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
logging console critical
enable secret 5 XXXXXXX
resource policy
clock timezone PCTime -6
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip source-route
ip cef
ip tcp synwait-time 10
no ip bootp server
ip domain name domain.com
ip name-server 198.6.1.1
ip name-server 198.6.1.2
username field privilege 15 secret 5 XXXXXXX
crypto ipsec client ezvpn CHI-GATEWAY
connect auto
group Group1 key XXXXXXX
mode network-extension
peer 65.x.62.17
peer 65.x.62.18
acl 100
username FieldRouter password XXXXXX
xauth userid mode local
interface FastEthernet0/0
description Inside LAN Interface
ip address 172.27.51.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
crypto ipsec client ezvpn CHI-GATEWAY inside
interface FastEthernet0/1
description DSL Backup
ip address 192.168.1.2 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface Serial0/0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
encapsulation frame-relay
ip route-cache flow
ip tcp adjust-mss 1300
service-module t1 timeslots 1-4
frame-relay lmi-type ansi
interface Serial0/0/0.1 point-to-point
description T-1 Internet - Main
ip address 202.x.x.146 255.255.255.252
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip inspect SDM_LOW out
frame-relay interface-dlci 901
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/0/0.1
ip route 10.1.3.0 255.255.255.0 172.27.51.2
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
logging trap debugging
access-list 100 remark SDM_ACL Category=4
access-list 100 permit ip 10.1.3.0 0.0.0.255 any
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 4000 1000
end
Thank for the help!
132
