Help with EIGRP and variance
All,
I have set up a lab in gns3 with eigrp to test the variance command. I have the following routes on one router:
<b>D 100.100.100.0 [90/435200] via 10.0.0.2, 00:01:24, Ethernet0/2
[90/435200] via 50.50.50.2, 00:01:24, Ethernet0/1</b>
My topology table shows three entries:
<b>P 100.100.100.0/24, 2 successors, FD is 435200
via 50.50.50.2 (435200/409600), Ethernet0/1
via 10.0.0.2 (435200/409600), Ethernet0/2
via 10.25.25.2 (45893376/153856), Ethernet0/0</b>
With a variance of 3 (3*153856=461568), I should see the third entry via e0/0 in my routing table, correct? Am I miscalculating, or will only two routes at a time only show up in the routing table?
John
HTH, John *** Please rate all useful posts ***
2 ACCEPTED SOLUTIONS
Blue
Re: Help with EIGRP and variance
John:
Good morning.
You are making a mistake with the calculation.
Its not 3 x 152,856...
It should be 3 x 435,200...which is about 1,300,000
Your total metric cost for the 3rd route is 45,893,376...
That is more than 100 times the cost of the primary routes (successors).
You have to compare the overall metrics, not just the FD of one candidate route to the FD of the successor...
Victor
John,
via 10.25.25.2 (45893376/153856), Ethernet0/0. Well,153856-RD < 435200-FD. But 45893376 divided by 435200. The result is 105.45. What about the following commands.
router eigrp XXX
variance 106
HTH,
Toshi
Blue
John:
Good morning.
Victor
John,
router eigrp XXX
variance 106
HTH,
Toshi
Hi Victor,
How are you going? Seems we did at the same time. Let's start with math calculation for today. (grin)
Toshi
That was it =) Thanks!
154
