Webcast-Catalyst9k
Help with "sh oer master traffic-class" output?
  Hi everyone,
   I'm working with PfR/OER and am studying the output of "sh oer master traffic-class," trying to understand everything in that display.  Specifically, I'm interested in the below chart:
2811-LSL#show oer master traffic-class detail
Age       Border          Interface       OOP/RteChg Reasons
Pas: DSum  Samples  DAvg  PktLoss  Unreach   Ebytes   Ibytes     Pkts    Flows
Act: Dsum Attempts  DAvg    Comps  Unreach   Jitter LoMOSCnt   MOSCnt
00:55:33  1.1.1.1         Se1/0.394
        0        0     0     1069        0  1023281        0     8691     2149
      750        5   150        5        0        N        N        N
What I'm looking for is a detailed definition of what all those values in the chart are.  For example:  I presume "Dsum" is "Delay Summary" and the measured unit is milliseconds.  And what exactly are "LoMOSCnt," "Comps," "OOP/RteChg," or "Ibytes?"  The online Cisco documentation I've seen does not say.
   Can anyone point me to some more specific info?
Everyone's tags (3)
Hall of Fame Super Silver
Re: Help with "sh oer master traffic-class" output?
Hello Peter,
not all fields are described in OER command reference
http://www.cisco.com/en/US/docs/ios/oer/command/reference/oer_03.html#wp1065811
but you can find there some explanations
Los = Loss
MOS : indicates packets containing MOS payload in order to perform VoIP quality test
so LoMOSCnt should be number of MOS packets lost
MOSCnt : total number of MOS packets
Ibytes = ingress bytes
Ebytes= egress bytes
OOP/Rtechg =  second part should stay for route change, first part could mean out of path packets that have travelled on other paths rather then on monitored /expected ones
Dsum could be the sum of delays (750) to be used to calculate average delay and jitter (delay variation)
if so Comps could mean compliant samples (with delay in SLA)
Hope to help
Giuseppe
Hi Giuseppe,
Thanks for the tip! I wonder why Cisco doesn't document this information. These statistics seem meaningless if you don't know what they are. Oh well.
Do you mind taking a quick glance at the below; I've tried to expressly document every stat. In particular, I'm still confused about "Samples," "Attempts," "Comps," and "Jitter." (I know what jitter is, but don't see how it is calculated here.)
Sorry, for some reason the rest of my email was chopped off.  Here's what should have appeared after the above text:
Age               Timestamp marking the end of a monitoring period
Border            IP of Border Router
Interface         Int on Border Router
OOP/RteChg        Reasons     Number of packets which have traveled on Out Of Path (OOP) routes than over monitored ones.
Pas:DSum          Sum of packet delays to be used to calculate average delay and jitter
Pas:Samples       ???
Pas:DAvg          Average Delay per packet  (Pas:Dsum/Pas:Pkts)
Pas:PktLoss       Number of packets lost
Pas:Unreach       Number of packets sent to an unreachable prefix
Pas:Ebytes        Number of bytes egressing the router
Pas:Ibytes        Number of bytes ingressing the router
Pas:Pkts          Total number of packets seen on this interface
Pas:Flows         Total number of flows seen on this interface
Act:Dsum          Sum of packet delays to be used to calculate average delay and jitter
Act:Attempts      ???
Act:DAvg          Average Delay per packet  (Act:Dsum/Act:Pkts)
Act:Comps         Compliant samples  (???)
Act:Unreach       Number of packets sent to an unreachable prefix
Act:Jitter        ???
Act:LoMOSCnt      Number of MOS packets lost
Act:MOSCnt        Total number of MOS packets
        Thanks!
                  -Pete Hummon
Hello Pete,
I tried to look for MOS test description.
There are a number of qualifiers frequently appended to MOS, including MOS-CQS, MOS-LQS, etc.  Refer to ITU-T Recommendation P.800.1 for a description of those.
Resources: ITU-T Recommendations P.10, P.800, and P.800.1
http://www.itu.int/itudoc/itu-t/aap/sg12aap/history/p800.1/p800.1.html
this should give you hopefully a background to understand all the terms
Hope to help
Giuseppe
   Great, thanks Giuseppe!
   I'm surprised Cisco doesn't have some official documentation, but oh well.  The link you've found looks very promising, though.  I think it will do.
          Many thanks!
                 -Pete
   I can't for the life of me figure out how to mark this thread as "Answered."  OK to close this out...
        -P
Hello Pete,
it is not possible to rate your own posts, but you are allowed to rate the posts of other people using the stars on the left bottom corner
Best Regards
Giuseppe
   Thanks again Giuseppe,
   I don't want to rate my posts; just close out this thread.  You successfully answered the question I posted.
            Thanks again!
                    -Pete
750
